People with drops- how do you change fluids (oil, trans, etc)?
Old Jun 11, 2003 | 09:18 AM
phenryiv1's Avatar
Mod her. Ate her.
I cannot get the max or my wife's celica up on ramps w/o scraping. How do you guys do it? Do you just use a jack and/or jackstands?
I cannot fit under there w/o some sort of height boost, either.
Old Jun 11, 2003 | 09:29 AM
Kashoggio's Avatar
i use a regualr 4 point car lift
Kashoggio's Avatar
Old Jun 11, 2003 | 09:50 AM
Str8ridin's Avatar
I use a lift and jacks....it just takes a few more steps to get it up. Basically, you will have to get the jack under the car (where the lift bar bolts into the frame) and lift it to a point where you can fit the stands under safely (I use the tow hooks). I then rest the car for a moment and then reposition the jack under the car to where I can get a better angle to raise it higher. After it is up higher, I move the jack stands to a more safer place (behind the front wheels under the load point) and I'm done. It's not as complicated as it sounds!
Old Jun 11, 2003 | 09:54 AM
phenryiv1's Avatar
Mod her. Ate her.
Thanks for the input...it seems excessive to have to use jacks and jackstands just to change the oil, btu I have them at the house, so why not. My ramps just feel like a real waste of money now...nothing I own can go up them!
Old Jun 11, 2003 | 10:24 AM
njmaxseltd's Avatar
Back the car into your driveway and hang the front end over the aprin. Gives you much more clearance because the aprin is sloped down! Then I usually just put my floor jack under the main support beam and jack it up a little more so I can get under it even better.
Old Jun 11, 2003 | 10:56 AM
slizan99's Avatar
i just slide a low clearence oil drain pan under the car and drain it
Old Jun 11, 2003 | 11:25 AM
Anachronism's Avatar
I bought some 'low profile' ramps at the auto parts store and my car goes up them just fine. The are made of plastic, Rino Ramps maybe?
You could put a couple 2X8s or something just before the ramps to give you an extra 1 1/2 clearance.
Old Jun 11, 2003 | 11:49 AM
phenryiv1's Avatar
Mod her. Ate her.
I live in an apartment, so no apron to drive it up on. Good thought, though.
I can BARELY get my arm to the drain plug on the maxima because of the end-mounted drain plug, but the filter is a huge pain in the butt. I really need some clearance to get it off w/o spilling oil everywhere.
The Celica is another matter. I am stumped b/c the owner's manual does not even list where the drain plug and filter are located, so I do not even know where to start, and there is NO WAY I am fittign under that, even @ stock height.
And before someone suggests going on a diet, I am not too FAT to fit under there!
Good idea on the wood as a small spacer. 1.5" should be plenty of cpace to get the celica up there...
The box for my ramps showed some extensions I could buy, but I tossed the box and the store no longer carries them so I cannot contact the manufacturer until I figure out who made them...
Old Jun 11, 2003 | 12:08 PM
slizan99's Avatar
walmart carries ramp extensions
Old Jun 11, 2003 | 08:25 PM
99pearlGXE's Avatar
Easy Oil Chg => remove tire well mud shield
I also own ramps, but was surprised to find that I did not need them recently when I changed the oil and filter on my 99 Maxima.
I simply removed the mud shield in the front wheel area on the passenger side. With this shield removed (4 simple screws), I had full and easy access to both the oil pan drain nut and the oil filter.
No ramps, lifts, stands, etc.
Old Jun 12, 2003 | 07:02 AM
slizan99's Avatar
thats how i do mine.
sctludwig
Sep 1, 2022 01:32 PM
kjlouis
Oct 3, 2015 05:29 AM
boomerbrian
Sep 4, 2015 08:25 AM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
