braking
Old Jun 11, 2003 | 04:02 PM
FAST97MAXX's Avatar
braking
is it bad to shift in neutral when braking? or does it help the braking? someone answer i have heard many diff. rumors
Old Jun 11, 2003 | 04:09 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Re: braking
For automatic car... well, let say you are stock in traffic for more then 20 min and you not moving its good to put in nutral. you take the load of tranny and engine. But when you brake its not that its bad. But it won't help your breaks. Because you just takeing the car out of the gear. On my car I know this it that when I break it down shifts. Also I would say if you do it too much it will ware out the clutch pack in the tranny and also makes the tranny to run hotter. I could be wrong. But let see what others will say.
Old Jun 11, 2003 | 06:04 PM
Maxima95Tuner
Automatics dont have clutches actually, it's a torque converter. And no it isnt bad to shift into neutral. When you have it in drive, and you hit the brakes, its nearly the same as having the car in neutral, only you still have the RPM up. It isnt bad at all to do that.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
