Which setup will yield more power
Hey Guys,
This is what I am debating. I do not want my setup to be too loud but want it too have a deep growl and good gains
First set up
Warpspeed aluminized ypipe,Carsound cat Apexi Ws Exhaust (2.25")
second set up
Warpspeed aluminized ypipe, 2.5" resonated bpipe, carsound cat, universal exhaust (borla, Flowmaster)
I was wondering which would be a better set up. I will be needing to cut a hole in my ionic rear to fit the exhaust tip. Thanks in advance
First set up
second set up
Re: Which setup will yield more power
just keep your stock muffler and you should be fine. your not getting a fart can are you? i doubt a new cat and muffler will give you any gains in hp. make sure your b pipe is resonated. have you looked into budget im sure they are a lot cheaper than warpspeed.
good luck
good luck
I have a similar setup with the borla muffler and i have to go to court cause a cop thought that i was breaking the law by having a modified exuast. With FF2 out its hot to be noisy these days.
