Need to know how to install a monitor in my 95 maxima
Old Jun 11, 2003 | 11:01 PM
ronnyblaze03's Avatar
i need some info on how u mount a 7" monitor in my dash where the old bose stereo was. and this question is for devon and his maximus. what kind of screen is that
Old Jun 11, 2003 | 11:24 PM
TylerBorg's Avatar
Most people here use the 7 Inch Microvision Screen that Redmax sells in the Ground Deal forum.
As for install, I'll let you know when I get mine next week
Old Jul 10, 2003 | 08:20 AM
Capitone's Avatar
Did you ever get around to the install?
Old Jul 10, 2003 | 08:59 AM
XXXL Cracker's Avatar
The install is very simple. The screen has a video out and three wires. I only connected red 12v and black ground. The screen will slide right into the double din space and all I needed to do was tighten the frame and it is fine.
You will need to wire a switch to turn the screen on and off if you connect the orange wire.
If you do not use the orange wire, you will need to modify the trim for the eye for the remote to be exposed.
Perhaps some others can post a little info on how they installed it.
Total installation time was about twnety minutes with most of that time spent taking apart the dash and reassembling it.
D
Old Jul 10, 2003 | 10:03 AM
Capitone's Avatar
D
Im Glad you replied dlicari,
What year maxima do you have? Reason I ask is the install you dipicted above is a far cry from I experienced myself during installation. The tv is in and working fine, but the process was not cut and dry at all. I HAD TO modify the plastic surrounding my screen in order for it to fit, there was just Nooo way it would have fit otherwise. Install as you mentioned caused the dash piece to bend slightly inward causing gaps around the sides where it meets the Screen. The only explanation I can could up with for these sort of differences w/install is model year. Mine is a 97 and I know some of the newer (maybe even older) models incorporated slightly different HU's, and perhaps even the bracket that held the HU's in place. There's even a difference between trim Levels in the same year i believe, besides the obvious Bose and nonBose HU's. I think THIS is why some people have been having problems and others have not. Let me know!
P.S.- I think the factory settings on the Screen are fine. that said, do you really think being able to use the remote is necessary if you've rigged a switch? Im thinking of doing just that, but maybe I missed something.
Old Jul 10, 2003 | 11:32 AM
I have a 1997. Do you have the screen edge on the front of the trim piece or behind the trim?
I have my screen mounted so it sits behind the dash trim.
BTW, I have a 1997.
D
Old Jul 10, 2003 | 12:14 PM
Capitone's Avatar
BTW, I have a 1997.
D
I have it sitting behind the dash piece. What model do you have Se, GXE, or GLE? We have the same years, so maybe it's the model in the year. Better yet, did your Factory Stereo fill up the whole square or did use half for the radio and the other half for a tray? This is really wierd, Im not electronics genious, but I spent every bit of 3 plus hours trying to figure what everyone meant by the screen Fitting just right but a little snug. Things were VERY snug. TOO snug, the bending was bad, so I HAD to modify.
Dman1989
19
Aug 17, 2015 03:44 AM
Team STILLEN
Aug 10, 2015 04:29 PM
MikesChevelle
Aug 6, 2015 11:36 AM
