A/C and Heat fan Only work on no.4 speed?
Old Jun 13, 2003 | 03:29 PM
bobjohnson's Avatar
Blazin......
Hey guys. My god today is another day with my max. TOday my a/c and heat only work on speed 4. it blows hard on 4 but still why wont it work. Any Help is so appreciated from the org. Thanks guys.mwest
Old Jun 13, 2003 | 03:47 PM
Flava_24/7's Avatar
Boosted Panda
Re: A/C and Heat fan Only work on no.4 speed?
You have a bad blower motor resistor, cheap and easy to fix. Its behind your glove box. Do a search, or if you have a Haynes it will walk you through it. It takes about 20 min. to replace and the dealer normally has them in stock.
Old Jun 13, 2003 | 03:51 PM
bobjohnson's Avatar
Blazin......
thanks man. hey i got my haynes manual in front of me right now. is it in the cooling section or u think the manual even points to the problem, like with a pic or what not.thanks aagain
Old Jun 13, 2003 | 04:37 PM
bobjohnson's Avatar
Blazin......
bump*
Old Jun 13, 2003 | 07:34 PM
Flava_24/7's Avatar
Boosted Panda
Okay, Im looking at my manual right now. Its in the cooling,heating and air conditioning systems. In my book its chapter 3 sectio 3-8. It clearly decribes the repair and has a pic with a arrow pointing to it. Go to the dealer, ask for a blower motor resistor for you car. Look at it real good. That way when you take off the glove box you will know what to look for and replace. Peace!
Old Jun 13, 2003 | 07:47 PM
bobjohnson's Avatar
Blazin......
same as in my book. thanks for the help,
Hey i got a question. u think if someone, say a dealer ship jumped my starter to get it start instead of turning the key. You think that would have caused this to blow or whatnot.
Old Jun 13, 2003 | 08:13 PM
Flava_24/7's Avatar
Boosted Panda
I doubt it.
Old Jun 24, 2003 | 04:59 PM
n2oMike's Avatar
I have the same problem...
However, I did NOT perform a search before diving into the dash. I pulled the mid section out of the dash and checked the switch (which was ok, the Haynes manual has the switch termainals backwards). I made my way down to the blower motor to check things out... and FINALLY discover the resistor was bad after checking the resistance of each element.
It SURE would have been nice to have performed a search FIRST!
Oh, the car has the original in-dash 3-disk CD changer and cassette... The CD player quit working some time ago, as did the tape player. Now, only about half the buttons on the radio work. I was confused about everything before today. I tilted the center dash assembly forward, and it sounded like a friggin' piggy bank! Turns out, our toddler aged son made a habit of putting coins in the CD and Tape slots!!!!
Oh well, time to order a resistor... and contemplate what to do about the radio.
Parenthood.
Old Jul 7, 2003 | 02:43 PM
bobjohnson's Avatar
Blazin......
Hey whats up all. Hey i tried looking for this Resistor the other day so i could talk it up to the dealer before i bought the part.. 1 Problem. I cant seem to get too it. Ok when you remove the glovebox and your looking into it, ill see the rubber glove-like thing over the motor but theres no way to really take it off without tearing everything apart.. any ideas??
I cant really seem to get to it very good at all....
Any help Guys...
Old Jul 7, 2003 | 03:20 PM
n2oMike's Avatar
It's easy to get to without taking the glovebox out. Directly under the glovebox, there's a plug on the bottom part of the heater/ac box. Unplug this, then take the two phillips screws loose. It will pull right out. It will have a 'credit card' looking thing attached to it that goes up into the slot.
It only takes about five minutes or less to change. They cost around $27 plus shipping.
Good Luck!
Old Jul 7, 2003 | 03:24 PM
bobjohnson's Avatar
Blazin......
i never heard that you could do it without taking the glovebox out but ahh ill give it a shot. thanks.
Old Jul 7, 2003 | 04:04 PM
n2oMike's Avatar
Yes, it's plainly visible directly below the glovebox. Just take the horizontal wiring connector loose and unscrew the thing it snaps into. It looks like part of the housing, but it is the resistor. It will then slide right out.
Mine is a 98' model.
Good Luck!
vingodine
45
May 21, 2016 12:46 PM
dr3am
25
Oct 22, 2015 08:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Alberto10mg
Aug 25, 2015 12:54 PM
kenc15
Aug 5, 2015 08:29 AM
