transmission/ overdrive prob, any advice
Old Jun 14, 2003 | 03:03 PM
drageron's Avatar
i just started feeling a wierd slip from my tranny and i need to know if anyone has gone through this or what i should do about it. my ecu says that the problem is= improper shifting to 4th gear / o/d, (AT)
it feels like their is no overdrive and i cant get the rpms to drop on the highway, the strange part is that in 3rd when i let off the gas the rpms go right down to 1-1.5 until i give it more to get the whels to spin at like 5 thousand. im not so sure what to do about it right now has anyone had this happen
oh i checked the tranny diagnostics and it led me to no problems and the fact that the diagnostic check worked makes me belive that the computer has to still be good maybe its a sensor? i just changed my o2 sensor that code finally disapeared any help? pEace
Old Jun 15, 2003 | 05:03 PM
drageron's Avatar
well guess im in it alone
Old Jun 15, 2003 | 05:38 PM
infinitiman96's Avatar
sounds like your converter isnt locking, try changing your tranny fluid
Old Jun 15, 2003 | 10:17 PM
BadKarma99-4spd's Avatar
check your tranny fluid level, if its low or high it will slip and or lock you out of some gears.
good luck
Old Jun 16, 2003 | 11:45 AM
drageron's Avatar
it seems to me that the fluid itself wouldnt cause that problem and i dont know how the converter works but if that seems to be the problem then maybe your right does the flud itself have anything to do with locking the converter?
Old Jun 17, 2003 | 12:59 PM
drageron's Avatar
ok
Old Jun 17, 2003 | 01:49 PM
XXXL Cracker's Avatar
Originally posted by drageron
ok
not enough or too much fluid will equal imprper pressure.... the tranny works via transmission fluid pressure.
Based on what you posted above, your tranny may be on its way out.
Year car:
miles:
Tranny fluid flushed ever:
This will help you to troubleshoot further.
d
Old Jun 17, 2003 | 09:13 PM
rluckas's Avatar
I got the same problem, have had it for months now, haven't driven on the highway in what seems like forever. Changing the fluid can be the answer in this situation, but changing my fluid hasn't helped. I've been through all the same diagnostics, and Nissan tells me everything is fine with the transmission. It's just GOTTA be a sensor of some sort. I'd love to hear further opinions, it's a real bummer...
Good Luck with yours...
Old Jun 18, 2003 | 06:42 AM
drageron's Avatar
well i just wrenched on my car and changed the tranny fluid and thatr didnt seem to help, went to the dealer --- they dont know, and now im stuck and the starter is acting up with it, dont wanna opay mad loot to fix it cause i want rims, now i am thinking its a REVOLUTION SENSOR and im pretty sure it is. its wierd cause i got a rebuilt tranny about 7000 miles ago from ammco im gonna call em now and find out if im still under warantee. wish my a$$ some luck
Old Jun 18, 2003 | 04:10 PM
drageron's Avatar
AAMCO they fixin that **** fo free ***** f@ck@s
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
