Maxima Relcutant to Start
Old Jun 17, 2003 | 01:03 PM
BatKeith's Avatar
I insert the key and turn it to ACC, everything is fine, I turn it to ON, everything is still as it should be. When I try to start the car, sometimes it doesn't want to. I don't hear the starter going, the fuel pump doesn't turn on, nothing in the engine gets power. At first I just wriggled the key, and after a couple wriggles it would start. Now I've noticed that it is more eager to start when I push the key down and away from me.
Does this sound like something is loose, broken, or bent in my ignition? My key might be dull, too. Anyone have any other input?
Old Jun 17, 2003 | 01:23 PM
njmaxseltd's Avatar
Sounds like you need a new ignition switch.
Old Jun 17, 2003 | 10:54 PM
maximizd97's Avatar
Could be a starter solenoid...same symptoms my old exploder had. If thats the case, make sure if you have it repairedd professionally, do NOT let them change the starter, cuz im sure its fine.
Old Jun 18, 2003 | 07:00 AM
cmac95gxe's Avatar
Maximaniac
I think you're right about this. I have the same problem. I've been using my automatic start because the car doesn't always start with the key. I'm going to check this out. Thanks.
Old Jun 18, 2003 | 07:03 AM
njmaxseltd's Avatar
If it starts with the auto start and not always with the key, then you definately need a new ignition switch.
Old Jun 18, 2003 | 07:06 AM
cmac95gxe's Avatar
Maximaniac
I'm checking out prices right now. Thanks again. Do you know how hard it is to install?
Old Jun 18, 2003 | 07:30 AM
MaximaMoJo's Avatar
It is pretty easy I think, do you have a haynes manual, if not get one. I think you just take the plastic casing off around the steering wheel unhook the ignition switch unscrew some screws and that is that. Not sure though?
Old Jun 18, 2003 | 08:32 AM
cmac95gxe's Avatar
Maximaniac
Yea I have a haynes manual. I'll take a look at it. I was told that the bolts that hold the switch don't have heads so that they can't be tampered with which make the job alot harder.
Old Jun 18, 2003 | 11:08 AM
BatKeith's Avatar
Alright Cmac; if that works for you can you please post about it when it is done? I don't have a lot of free time and want to cut down on this project since I'm also planning on regreasing my starter, cleaning my throttle body, installing my 'y' and giving the car a good detailing.
Old Jun 18, 2003 | 05:43 PM
cmac95gxe's Avatar
Maximaniac
No problem.
Old Jun 18, 2003 | 05:49 PM
boybilly's Avatar
Re: Maxima Relcutant to Start
I had the same problem. It was the ignition switch. It's been fine since I changed it.
Old Jun 19, 2003 | 01:19 AM
BatKeith's Avatar
boybilly, that is very encouraging. How much did that cost and where did you get it? Is an ignition switch Maxima-specific or can I just get the sucker at Pep Boys?
Alright, I've been thinking that since I enjoy fiddling with electronics and my grandfather suggested that I bypass the starter if I have to anyway, perhaps I should rig up a "Starter" button for my car so that when you have the key in the On position, you just have to push my button to start the car. I would probably put this in the ash tray since I don't smoke, and I would leave room for a toggle switch for the naws I plan on getting.
Does this sound too crazy? I have all summer until the next semester of school starts, and this start-button thing doesn't sound like it will cost much money, do any of you think that it is outright impossible / haltingly difficult?
Old Jun 19, 2003 | 02:35 PM
BatKeith's Avatar
bump ? Hey, i went from newbie to enthusiast. excellent.
Old Jun 19, 2003 | 03:51 PM
boybilly's Avatar
I bought the Nissan part. I don't know if it is available otherwise. It costs less than $30 and takes about an hour to replace. I would go that route rather than wire another switch.
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
halfpol
Aug 5, 2015 08:24 PM
dauntlessmax
Aug 5, 2015 10:29 AM
Jcof88
Aug 3, 2015 10:43 PM
