starting car w/ clutch pedal
starting car w/out clutch pedal engaged
I was fueling up yesterday and got back in the car, and it wouldn't start. nothing would happen, not even the solenoid click. however the radio, lights, etc worked fine though and i narrowed it down to the button behind the clutch pedal that allows you to start the car when the clutch is pressed to the floor. well i unplugged the wiring going into the button and shorted it w/ a paperclip. sure enough, she started right up
basically i'm just wondering if there is any negative effect when you start a car without the clutch engaged. because i might just leave it the way it is now. thanks for the advice. sean
Re: starting car w/out clutch pedal engaged
yeah it's always in neutral when i start it. but i thought there might be some reason that you typically have to start a 5sp car with the clutch engaged.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
ef9
Aug 13, 2015 01:19 AM
