auto tranny gear lock
Old Jun 19, 2003 | 08:32 AM
MarcGXE95's Avatar
Is there a methode I could lock my tranny into 2nd or 3rd gear on a dyno run?
-Has NE1 tryed to do a run with the throttle position sensor un pluged?
-Has NE1 tryed a run with the knock sensor unbolted from the engine?
Old Jun 19, 2003 | 08:42 AM
njmaxseltd's Avatar
Why would you run your car like that? Besides tripping your CEL, it wouldn't shift right, and run with retatrded timing because of the disconnected KS.
Old Jun 19, 2003 | 09:20 AM
MarcGXE95's Avatar
If the KS is still plugged in and just not in contact with the engine you will not get a code and you wont retard the timing. Note that I was only talking about trying it on the dyno for real mesured results.
Old Jun 19, 2003 | 10:31 AM
njmaxseltd's Avatar
Ahhh unbolted from the engine. I missed that line.
Take OD/OFF and it wount shift out of 3rd into 4th. I don't think there's a way to lock it in 3rd for the entire run. The TPS has 2 plugs, one is simply a switch that sends a signal to the ECU to indicate closed throttle or WOT. If you figure out which plug that is, disconnecting it may let you pull in 3rd from a lower speed without it downshifting into 2nd.
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
zmcneely13
Sep 26, 2015 02:26 PM
