first gear ?
Old Jun 21, 2003 | 11:28 PM
wrongway15's Avatar
first gear ?
ok when i try to start from a stop in 1st, sometimes it seems that i have to let off the clutch to the beginning of the friction point and kinda leave it there and then slowly "slip" it up to get going (using no gas)
other times, the clutch seems "normal" and i get let up quicker
i cant seem to figure out why this is, but its really annoying because i keep stalling when it happens, and it'll be that way for a while, then itll be fine for a while
any clues
Old Jun 24, 2003 | 11:27 AM
wrongway15's Avatar
bump
Old Jun 24, 2003 | 02:32 PM
nismos14's Avatar
§è~® f®ÈÄk
Re: first gear ?
any clues
how many miles on the clutch? u may have a bad clutch or the slave or master cylinder may be bad.... and when ur bringing it up with no gas u should have to go slowly at the grabbing point...
Old Jun 25, 2003 | 07:02 AM
wrongway15's Avatar
clutch is only a few months old
but what i am trying to say is i have to go release at different speeds sometimes when releasing first gear even on level surfaces
Old Jun 25, 2003 | 07:09 AM
nismos14's Avatar
§è~® f®ÈÄk
hmm has it been like this since u got the clutch installed?
Old Jun 25, 2003 | 11:36 AM
MaximaMoJo's Avatar
Was the flywheel resurfaced when the clutch was replaced? What about the fluid for the clutch(next to the brake fluid reservoir)? These are my two guesses.
Old Jun 25, 2003 | 11:50 AM
wrongway15's Avatar
ummm...i cant remember when the problem started...i just started with a 5spd and basically taught myself. within a couple of months the clutch started to go and i drove on it bad for a while.
yes, the flywheel was resurfaced.
i will check clutch fluid tonite. should i try to bleed the clutch lines? never done this before but i just bought a haynes last nite and may be able to give it a go.
thanks for the replies
Old Jun 25, 2003 | 01:36 PM
wrongway15's Avatar
nismos...yes i do believe it happened with the old clutch also if i remember correctly
Old Jun 25, 2003 | 02:59 PM
nismos14's Avatar
§è~® f®ÈÄk
yeah i would definately say bleed the clutch also check in the faq about the clutch self adjustment / moving. that might be the problem cuz it seems like ur clutch is grabbing at different points at various times, right?
Old Jun 25, 2003 | 03:11 PM
wrongway15's Avatar
nismos...actually i came on just to post that the clutch was grabbing real high today...annoying cause i kept stalling
ill check the faq, i remember there being something about clutch automatically adjusting, but i thought that meaant the peddle actually moved to different heights not the friction point
Old Jun 25, 2003 | 04:49 PM
nismos14's Avatar
§è~® f®ÈÄk
good luck bud, i hope u can figure this sucker out!
Old Jun 25, 2003 | 07:31 PM
Dev's Avatar
Dev
Re: first gear ?
any clues
i don't understand what's actually wrong with your car...
it seems okay to me...
about the stalling, you're letting the clutch out too fast without enough throttle.
instead of remembering where you should feel the friction point, just let it happen...and get a feel for the car and adjust your driving techniques to suit it.
Old Jun 25, 2003 | 07:56 PM
maxspeed96CT's Avatar
The original VQ...
similar thing happens to me with my act when its real hot out, i have to rev to like 1.5k or the car bogs down, a friend of mines told me its cause the motors hot and the short ram in 90 degree weather doesn't help.
Old Jun 27, 2003 | 04:56 PM
wrongway15's Avatar
ok well i cant get the master clutch bleeder opened due to corrosion and can barely reach the lower one....
i cant get the clutch engagement adjustment to move cause its a cramped space up there (damn adjustable wrench)
this sux cause my clutch is being a PITA
Old Jun 27, 2003 | 05:00 PM
wrongway15's Avatar
Re: Re: first gear ?
i dont understand whats wrong either...
i usually use no throttle when starting from stops for normal driving...i dont want to replace the clutch again.
the friction point should stay the same and not move tho
Old Jun 27, 2003 | 06:42 PM
Dev's Avatar
Dev
Re: Re: Re: first gear ?
hmm...ok well...i launch off of idle...but i do apply gas at the friction point
kind of letting the clutch up as i depress the gas pedal
our clutch is self adjusting...so things might change...but VERY VERY little and very gradually...not enough to notice a difference
Old Jun 27, 2003 | 09:51 PM
ilumo's Avatar
Yea... I agree with Dev. I think its strictly human error, not a mechanical one. You even stated that you are learning how to drive a manual. The same symptoms that you describe happened to me when I first started to learn. The friction point should stay the same (relatively), but the way you position your feet could make a difference. I always thought the point shifted as well, but it was because I was using different parts of my feet to press the pedal. When you start in first, you should give it a little gas a well when you feel it grabbing... if you dont, and let go too fast, you wont have enough power to spin anything... therefore you stall. (i think)... well, good luck.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
