Where is and how to install Front Right Heated o2 sensor?
Old Jun 22, 2003 | 07:51 AM
Bmr4life's Avatar
ECU says mine is done, i reset it and it came right back up so I guess it needs to be replaced bad. So where is it and how do i do it. thanks
Old Jun 22, 2003 | 07:53 PM
ivelweyz
http://courtesyparts.com/A32_O2-sensors.html
Old Jun 22, 2003 | 11:19 PM
RA030726's Avatar
I'm nutty for Nissans
get an O2 socket and go to town
Old Jun 22, 2003 | 11:52 PM
krbga's Avatar
Easiest way...
1. Order the RH O2 sensor from Courtesy Nissan.
2. Jack up the Front end (passenger front area)
3. O2 socket from AutoZone. Remove old one/Replace with New.
4. Unplug the Old harness. Plug in the New harness.
*note you could also just take out the old one and clean it off with some Brake Cleaner and a Clean Terry cloth. Reset your Ecu to double check. This could save you some $.
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
