even after starter car still clicks someone help
Old Jun 22, 2003 | 10:32 AM
CitrusSpeed's Avatar
Alright i made a post yesterday about my car, it seems to start whenever it wants, sometimes after a few minutes sometimes it takes a day or 2 of sitting in the driveway for it to start, it makes no sense to me. so anyways i was told by a few memebers here on the org that it was a starter problem, so i took the old starter off and had it tested and sure enough it was the starter, so i come home put the new one on and guess what, same damn click , could it be a blown fuse for the starter or something like that cause i am at my wits ends here, someone help
Old Jun 22, 2003 | 10:45 AM
z32drifter's Avatar
check your batt cables make sure clean and tight...ok...check power connection at starter (lrg wire)..clean tight..has 12+volts...ok check switch wire....clean and makes proper contact....put your volt meter on the switch wire and have someone cycle the key a few times to ensure that you have power from the switch .....if all that is good ...you may have a defective replacement starter....you would not be the first
Old Jun 22, 2003 | 12:56 PM
sirveaux's Avatar
Check the battery too, I had a car once with starter problems, an when the starter finally went out, I replaced it but got the same thing. I had run down the battery trying to start it, and it just needed a jump. Worth a shot. I had this random clicking happen with my car, it is aggravating. I replaced the battery, starter, all cables, contacts, etc...never could get it squared away. Good luck.
-Ryan
Old Jun 22, 2003 | 04:27 PM
thanks for the help, i put the battery on a charger and it showed up very low, i am charging it now. hope it works.
Old Jun 22, 2003 | 05:44 PM
patel_anu's Avatar
if the problem persists than get your alternator checked out, your battery might not be recharging correctly
Lakersallday24
Jun 16, 2019 01:35 AM
homewrecker
Aug 24, 2015 08:56 PM
Samedi
Aug 13, 2015 04:05 PM
acw
Aug 13, 2015 12:50 AM
MikesChevelle
Aug 9, 2015 11:50 AM
