Modifying fog housing to fit HID bulb
Old Jun 22, 2003 | 05:34 PM
araffio's Avatar
To anyone that has HID fogs:
I'll be getting my Hanabi 8000k HID H3 bulbs for my fogs to match my heads later this week. I know that the bulb is too long to fit in the housing because of that plate that's in there.
Which method have you used to modify this....opening the housing and removing the plate or using a screwdriver to bend the plate and make room for the bulb? I'd think removing the plate would make them brighter, but also blinding. Any info is appreciated.
-Tony
Old Jun 22, 2003 | 05:44 PM
nismos14's Avatar
§è~® f®ÈÄk
will the housings be able to accept the heat? im sure there will be a lil more heat from the hid's than the stock 55'ers, right? or am i terribly mistaken?
Old Jun 22, 2003 | 06:04 PM
araffio's Avatar
The heat is not a problem, it's just making them fit in the housing.
Old Jun 22, 2003 | 06:12 PM
Chunger's Avatar
My other car is a Hybrid
Somebody posted this before... maybe it may help
http://www.geocities.com/jvxdriver/d...conversion.htm
Oh... Make sure the Return Wire doesn't contact the shield or you may lose your Ballast!
Old Jun 22, 2003 | 08:26 PM
minsbang's Avatar
Two HID setups?? Wow, thaT's Bright... Too bad i'm Baroque.. Can't wait to see some pics..
Old Jun 22, 2003 | 10:30 PM
ch13f's Avatar
HIDs give off less heat than halogen.
Old Jun 22, 2003 | 10:51 PM
araffio's Avatar
One more question...
Where should I mount the ballasts for the fogs? I have the ballasts for the heads mounted under the housings on the frame.
Old Jun 23, 2003 | 12:49 AM
97GLES's Avatar
ask pcguru from new york i know he has them in his 5th gen.
Old Jun 23, 2003 | 11:36 PM
araffio's Avatar
No one else has HID fogs??
Old Jun 24, 2003 | 06:32 AM
Tino98max's Avatar
tony ask jason sadler, i know he has that
Old Jun 24, 2003 | 07:05 AM
araffio's Avatar
Already spoke with him...looking for other people's thoughts
Old Jun 24, 2003 | 07:07 AM
Tino98max's Avatar
ok just checking
Old Jun 24, 2003 | 08:33 AM
cam_honestiam's Avatar
If you increase the length of the wire leads to the bulb, you can mount your fog ballasts near your headlight ballasts...
Personally, I would buy an electrical kit protector from your local electronics supply store, seal them inside the case (kit protector) in a way that allows for easy access should it be necessary. That way, they are weather proofed and shock protected.
Since I can't "see" what you are doing, that is the best I personally can come up with.
Old Jun 24, 2003 | 10:19 AM
araffio's Avatar
So the leads will be too short to mount the ballasts up by the headlights? I've never heard of an electrical kit protector. Maybe I'll bring the ballast with me to the store and ask them what's best for it. I don't want too much added size though since the space to mount the ballats is on the small side.
The Frye
Sep 2, 2021 11:03 AM
Vistance
Sep 17, 2015 05:17 AM
meccanj98
Sep 16, 2015 06:06 PM
meccanj98
Sep 16, 2015 07:23 AM
minsbang
Sep 11, 2015 08:48 PM
