Question on the EVAP box...
Old Jun 23, 2003 | 04:19 PM
D1NOnly34's Avatar
I've read a few posts that have been on the org, and read hwo it is quite easy to get to and to take out. Mine is making a hissing sound, like a leak of air from a tire. Is this normal? WHat could it be, a loose hose? I want to get to it but its been raining like crazy. If it was a leak, would this cause bad gas mileage? Thanks for your help.
Old Jun 23, 2003 | 05:53 PM
Rogo02SE's Avatar
The vacum leak should activate your CEL.
Best advice is to visually inspect it and see what's up.
The valve on the box tends to get rusty and stuck. It will create 01 11 code if I'm not mistaken.
It's an easy fix. You can take it apart and clean it with WD 40 or get a new one for like 30 bucks.
Old Jun 23, 2003 | 05:58 PM
D1NOnly34's Avatar
Naw, I dont have a CEL. The reason why I post about it is because one day I realized a hissing sound comming from my car, at first I hought I had a tire leak, but then the sound would go away when I turned off my car. The sound was comming from my drivers side rear wheel area. Then I started to think that sometimes I would smell gas around my car. But yea, no CEL at all, just the dam KS as usual =(
Old Jun 23, 2003 | 06:34 PM
Rogo02SE's Avatar
Must me a vacum leak.
When I disconected the hoses with the car running there was a definite hissing sound.
You gotta get underneath your car and make sure all the vacum lines are in place.
Good Luck.
Old Jun 23, 2003 | 06:45 PM
D1NOnly34's Avatar
I figured, how does this vacuum leak from teh EVAP box affect the car? I would assume if there was a leak there would be a CEL right? or is that just if it was not functioning at all. Would this leak cause a decline in gas mileage?
Unclejunebug
Apr 2, 2016 05:42 AM
tseng1023
Oct 15, 2015 08:30 AM
Socalstillen
Sep 26, 2015 12:01 PM
