Car Wont Start :(
Old Jun 24, 2003 | 08:11 AM
mAxPwEr4Us's Avatar
Car Wont Start :(
Hi my clutch is dead 2 mornings ago i tried to at least turn the car on and the car wont start.. when i turn the ignition on there's is noise tick tick tick tick i think i might need a new starter, but im no mechanic... any opinions would be great thank you
Old Jun 24, 2003 | 08:20 AM
s0ber's Avatar
bang on the starter.. its under the intake.. i just got mine rebuilt... aftermarket starters seem to not work on our car..
Old Jun 24, 2003 | 10:30 AM
WeST's Avatar
Your battery might also be too weak to start the car. How long has it been sitting? Did you leave any dome lights on or anything of such kind?
-Irena
Old Jun 24, 2003 | 11:45 AM
FLO_BOY's Avatar
Re: Car Wont Start :(
that ticking noise means one of two things:
1) your battery isn't strong enough to crank the starter.
2) your starter is bad.
first thing to do is to try "jumping" your car with cables...
if the extra power won't start the car, your starter is probably
toast.
good luck!
FLO_BOY
Old Jun 24, 2003 | 11:52 PM
mAxPwEr4Us's Avatar
Re: Re: Car Wont Start :(
toast.
good luck!
FLO_BOY
i have already tried to jump start the car, but it would still do the same thing.... i guess is my starter...i guess the clutch being dead has nothing to do with it right? and i also tried to reset my computer, and by accident i pass the stop limit so i forced it.. may be that has something to do with .. thank you for all the info
Old Jun 25, 2003 | 05:40 AM
goldmax's Avatar
Re: Re: Re: Car Wont Start :(
If your battery has developed a bad cell, you'll never be able to start it on a jump. Take the battery out and go and have it checked to see if it is ok before you do anything. My alternator died a couple of weeks ago and it killed the battery. Make sure your alternator is working well also!
Old Jun 25, 2003 | 06:11 AM
Jatan's Avatar
My dad's Accord wouldn't start so he towed it to his mechanic and he got the starter replaced, then it died again so he towed it back there again and he said the ground wire was bad. After he fixed that, the car is running again... He had the clicking noise and it wouldn't jump start either =P
Old Jun 25, 2003 | 08:47 AM
mAxPwEr4Us's Avatar
Re: Re: Re: Re: Car Wont Start :(
A lil bit ago i tried hitting the starter before i did that i tried to turn the car on and it seems like it would turn on very like half a second and then turns back off and makes the weird sound hhhrrrrggg like trying to turn back on, it wont, i just changed the battery like 2 or no more 3 months ago and they aslo check the starter and altenator when i changed it... when i took the intake apart i realized that the tick tick tick is been made the thing right next to the thing where you would push to make you engine sound... (i think that sometimes must of broken when i force the competer trying to reset it.. i pass the do not pass the stop limit.. or more ideas would be great.. thank you for you time
Old Jun 25, 2003 | 11:25 AM
mAxPwEr4Us's Avatar
Re: Re: Re: Re: Re: Car Wont Start :(
the part the is making the noise(tick tick tick) is the trottle body or something like that...my mechanic told me that it might not be the starter and it might be the computer.. how can i be sure what i need to buy??? please any ideas ??
Old Jun 25, 2003 | 01:25 PM
FLO_BOY's Avatar
Re: Re: Re: Re: Re: Re: Car Wont Start :(
you could swap computers with someone else's Maxima...plug and play!
...I'm not sure if the throttle body can make ticking noises???
I would *maybe* ask another mechanic to check it out...
FLO_BOY
Old Jun 25, 2003 | 01:55 PM
mAxPwEr4Us's Avatar
Re: Re: Re: Re: Re: Re: Re: Car Wont Start :(
FLO_BOY
why didnt i think of this before???
but i dont think i know anyone with a maxima that would take they computer off, could i buy it from the dealer and then return it if is not the computer.. if it is i'll just keep it and stay broke for another 2 weeks(how much are thing computers anyways)
THANK YOU SO MUCH FOR YOUR TIME AND HELP!!
Old Jun 25, 2003 | 01:59 PM
FLO_BOY's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Car Wont Start :(
they're not cheap...try a scrap yard, or, kindly ask
a fellow member who was close by to swap for a minute.
no problem! good luck!
FLO_BOY
Old Jun 25, 2003 | 02:02 PM
mAxPwEr4Us's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Car Wont Start :(
FLO_BOY
thank you.. anyone here around fairfax, va if you would come over i would pay for your time and gas
Old Jun 25, 2003 | 02:04 PM
mAxPwEr4Us's Avatar
FLO_BOY
mAxPwEr4Us's Avatar
FLO_BOY
Old Jun 25, 2003 | 06:51 PM
pMB's Avatar
pMB
ok I've had this problem also.
put your key, turn it 1/2 way (that is, don't fire up your engine) and try headlights.
If headlights work, battery is good.
I suspect you have a negative ground wire that is bust/not making contact/broke in the middle.
This has been a known problem in our maxima. For one, I had to pay $250 to learn the lesson.
It's where the thick wire cables do a 90 degree bend near the starter and engine block. Check the wiring first.
BTW, starters don't go die on you unless you try to crank it 30 times within 30 minutes.
Old Jun 26, 2003 | 09:45 PM
mAxPwEr4Us's Avatar
I'm pretty sure the wire is fine... it was working before and nobody mess with it, but the thing that i did mess with was the computer, i did something i was not suppose to do and i think i broke it, but i can't find anyone with another computer.. i did what you told me to do about the headlight and the battery is good... thanx for your help and time i really greatful
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
