Replacing Clearance Bulbs
OK, everyone says the clearance light housings that are immediately next to the headlight housings should just pop out, but this has proven quite frustrating. I know there is one screw on the inside that is holding the housing in, but... it seems like there is another screw on the inside holding it in that i can't seem to find.
A little help, please?
its trickey,
but if your just replacing the bulbs, you can change them without taking them out, just wear plastic gloves so you don't get any oils from your hand on the bulb you are going to replace(just in case you need them) and on the new bulb either. its a little funny but it can be done. if your hands are too big, get someone with smaller hands to do it.
good luck
good luck
Search? What? Huh?
Be careful!
When taking it out, I found the best way is to pop the furthest part away from the front of the car out first. After that, accessing the little ball & socket part is easy. Be careful when you do it though, I've got a little crack on one of mine because the car place I had do it used a wee bit too much force (and I didn't notice till the next week so I can't do jack about it) ..
umnitza
Sep 1, 2015 01:03 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
MikesChevelle
Aug 6, 2015 11:36 AM
