Fuel pump question.
Old Jun 25, 2003 | 07:31 AM
plurco's Avatar
Fuel pump question.
I just got a high flow 255LPH walbro fuel pump. I have two questions.
1. do I need a fuel regulator with this fuel pump? and
2. does the tank "have to" be nearly empty to do this or is it just easier?
Old Jun 25, 2003 | 07:40 AM
xHypex's Avatar
Re: Fuel pump question.
Technically No. I'm running a Walbro with the stock FPR (and colder plugs) and I'm still getting 21-22 mpg. You just have to stay light on the throttle and stay OFF of WOT. The car will have a higher fuel pressure across the board, but the O2 sensors should adjust the injector pulse width to compensate. If you're really concerned with power/gas mileage the FPR is worth it because you can adjust the baseline and WOT fuel pressure.
To give you an idea:
Stock baseline PSI is 34, WOT 43
Walbro baseline PSI 40, WOT 50
At WOT the car pretty much runs a straight fuel map and doesn't adjust the injector pulse width, so you're using the stock pulse width with 7 more PSI of fuel which should leave you really rich. I should be dynoing soon, so I can tell you exactly how rich.
You really should be at about 1/4 tank or lower. This will help minimize the gas you get on you and will make the experience much more pleasant. If you have the option, work outside with both rear doors open to minmize the fumes.
-hype
Old Jun 25, 2003 | 07:51 AM
plurco's Avatar
will it hurt my WOT performance if I do not use a new FPR?
Old Jun 25, 2003 | 07:53 AM
plurco's Avatar
also this is a high flow not a high pressure. does this matter?
Old Jun 25, 2003 | 09:11 AM
xHypex's Avatar
Yes it does matter. Sorry, I assumed you meant a Walbro high flow HP pump since thats what most people get. With the 255lph high flow you should be fine as far as fuel pressure goes. Any reason you got a 255lph over the 190lph?
-hype
Old Jun 25, 2003 | 12:18 PM
plurco's Avatar
it was free
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Mar 29, 2016 11:08 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
