Need Help Clearing Tails!!!!
Old Jan 31, 2001 | 05:22 AM
BlackMax62's Avatar
How hard is this process on a 98'. i know you have to heat up the lenses and then remove the orange peice..and replace with white lens...
There is a small peice of red lens in the corner of the bottom part of the tails. does this get removed as well..
Where can you get the material for the lens..and how long does the process take..
Any pics please...Thanks all im going to do this this weekend along with hooking up some subs..
Saber
Old Jan 31, 2001 | 06:40 AM
BlackMax62's Avatar
anyone???
little help here!
Saber
Old Jan 31, 2001 | 10:47 AM
Black97GLEnj's Avatar
Clearing the taillights...
Clearing the tailights isn't that hard, if you take your time. Check out Cheston's page for detailed instructions at MaximaDriver.com . He has a list of the materials needed, and a bunch of pictures as well. The process took me about 3 to 4 hours cause I had a hard time heating up the lenses to seperate them. It takes patience. As for the small red piece in the lower corner of the tails, I covered it up with the new clear lense, and it looks pretty good. Hope this helps...
Old Jan 31, 2001 | 11:19 AM
BlackMax62's Avatar
so...
so your saying that you removed the small red peice firest or you just covered it up with the new reflective clear peice..is that red piece connected to the amber peice???. ill check chestons website..thanks for the tips..
saber
Old Jan 31, 2001 | 11:28 AM
JacksMax's Avatar
http://www.vsdev.com/brian/taillights.html
Old Jan 31, 2001 | 12:17 PM
blackmax62
I left the red piece and covered it up with the clear lense. The red piece is not connected to the amber piece.
Old Jan 31, 2001 | 12:34 PM
ereet's Avatar
The little red piece is removeable
I think, there's acouple of people on the board that do it, and they remove the piece. However, they might do what Black97GLEnj said, and just cover it up. I'm not sure, I left mine with the little red piece in.
Old Jan 31, 2001 | 12:49 PM
BrianV's Avatar
Yeah the red corner piece comes out with one screw. You can leave it (Maxed-Bandit) left his in. I preferred to take mine out.
Hit up my website - http://www.vsdev.com/brian/taillights.html
I'll update it and be more specific.
Old Jan 31, 2001 | 08:40 PM
_DRU_'s Avatar
I'm a little confused...
so on the tailight part that is on the car(not the trunk) you can take out the top red piece and the bottom amber piece to make the whole thing clear? i just want to leave the top red and take the amber piece out. i can do that right? also, what can i use to heat it up to separate the lenses and will it be all gooey when i pull it apart? dont mean to sound stupid but ive never done it before. thanks
Old Feb 1, 2001 | 02:38 AM
metallic97gxe's Avatar
Master Will
read this thread.......
https://maxima.org/forums/showthread...threadid=12868
i can do that right? yes also, what can i use to heat it up to separate the lenses and will it be all gooey when i pull it apart? dont mean to sound stupid but ive never done it before.
thanks
I used a hairdryer in about 90 degree weather,and I did not take the little red corner piece out like brianv did.....
Old Feb 1, 2001 | 04:42 AM
BlackMax62's Avatar
ok next question Brian
What type of material do you use to put back in once the amber peice is out.where can i buy it??? Pep boys?? i will definately take that red peice out..i like the way it looks. im going to do this this weekend so give me the input...you guys are a big help..i can't wait to meet up with some people at a meet..Philly Style..
Old Feb 1, 2001 | 07:38 AM
JacksMax's Avatar
Re: ok next question Brian
Read this, the answer is in there.
Old Feb 1, 2001 | 08:35 AM
GTRBlkMax97's Avatar
Which
side of the damn tail light do you heat up the black part on the inside or the lense itself?
Old Feb 1, 2001 | 01:29 PM
You heat up both sides, but becareful not to melt either side. It takes a good amount of heat to sepreate the two pieces.
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
