pinging with 93 octane
I am getting slight pinging and have tried different gasolines, all 93 octane, it seems to happen once the engine is at operating temperature, temp gauge indicator is right in the middle of range.
Any suggestions, car is a 96 and well maintained, has 125k miles.
Re: pinging with 93 octane
Yes I agree with the last person to speak I have worked on many cars and carbon build up is a major factor....The symtomology is pinging slight loss of power....heads are usualy gunked up with realy hard *** carbon around the intake and exhaust valves this leaves less room in the combustion chamber therefore octain needs to go up...just like decking a head or using a thinner head gasket....In the old cars we would just ad a little (like a cup full)of water down the carb( when it was running) to burn it off it would smoke like a ***** and then it would be back to normal I'm not suggesting this by the way just a little history.
you don't see little amount of blue/dark smoke coming out from your exhaust, do you?
if so, your lifter is worn and gasket is leaking. That is, you are burning engine oil.
Check engine oil, fill up to normal level. This will stop pinging, if the above is the case.
Originally posted by SleepyMaxxx68
How much $$$ for the cleaning?
I recommend BG44K. Used it a couple times and it helped tremendously. I have a JWT ECU and was having to run 93 plus octane booster to keep from having KS codes. Ran a couple cans through on fill-ups and no problems since. It's good shiet.
![Stick Out Tongue](https://maxima.org/forums/images/smilies/tongue.gif)
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Yo! How many miles did you have on the engine when this started to occur?....also you ran two bottles through?...this did the trick? Thx for info
They have another product, Intake Cleaner, that I've used as well. You clean the TB and the IACV with it and then spray the rest of the bottle into the intake in short burst while the car is running. I've been really happy with their products.
I ran a can through one tank, then ran through a couple more tanks without it , and then ran another can through. Haven't had any more codes and the car runs A LOT smother. I have 115,000 miles on my car.
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
Sounds good,, I am gonna run a few bottles through...I did the throttle body cleanout @ 120 k miles,,,it was really gummed up at the plate and behind it, it ran alot better...I can imagine what it's like down inside.....did not clean beyond a few inches past the throttle plate though.
Where do I get this stuff at?
I get mine through a local parts supplier. I had to order my first can through an internet supplier before I found out they carried it. Do a search on google and you should be able to find it. Usually runs around $15-$18 a can.
fastcarny
10-06-2015 10:42 AM
JoshG
51
09-21-2015 10:41 PM
sdotcarter
09-02-2015 09:53 PM
