Rusted Rotor Help
Rusted Rotor Help
Ok guys, another problem I came across while trying to install my new rotors...My old ones WON'T come off!!! Unlike my rear rotors my fronts don't have that extra hole to sick a screw in to push the rotors off the hub. I don't know what to do, I thought about taking a rubber hammer and giving it a few hits but it doesn't seem very safe to do that. Anyone experience this before? What are my options? As usual any help will be great. Thanks.
Mason
Mason
Re: Rusted Rotor Help
Mason
Mason
Here's a link, and a bump on the thread too so it'll be easy for you to find.
http://forums.maxima.org/showthread....5&pagenumber=1
Heck, there's even a link in the thread with pics of the brakes and procedures.
I've seen this prob. before (I work as a detailer and constantly observe mechanics). The way ive seen this problem fixed is application of a hheavy lube (we have an industrial strength brake part lubricant for this) Spray around the 5 bolts and use a rubber mallet...its ok to hit it hard if youre not keeping the old. Just keep working at it if its stubborn...they can be!
Nosamo - I think you should trade up the rubber hammer for something with more density/mass. Don't hit the rotor in one location only. Work your way around it from the front and back as well. Just be careful of the studs. You might also want to look into penetrating oil & see if you can force some in behind the rotor hub somehow.
Originally posted by njmaxseltd
Big rubber hammer and wack it from behind.
It will pop right off.
p.s. we dimpled and slotted that sucker real nicely!
Update, its 2pm now and after 3 hours of baning the damn rotor from many different spots and thinking of ways I might be able to "push" it off I am exactly where I started. Frustrated I took a break and installed my new midpipe and took a lunch break, gonna get back on them rotors right after I eat and pick up some more blunt objects. At this point anything that's big and heavy that I might be able to use I've picked up. Be back in another 3-4 hours, hope it doesn't rain.
I've attached a really ugly picture I drew in MS-Paint to try to illustrate my point. Hope it helps!
04-16-2020 05:15 AM
06-06-2017 02:01 PM
RealityCheck
10-02-2015 06:34 PM
