Air conditioner Part NAME
Old Jun 28, 2003 | 07:02 AM
eclypsecl's Avatar
What's that thing that holds that gas it's on same side as steering wheel. Where the container has 2 metal rods coming out? I forgot the name of that part..it broke..let all the refrigerant out.or whatever it's called. is it hard to fix? Gas i can get..just installing the part again.
Old Jun 28, 2003 | 08:05 AM
tattoo's Avatar
is it a reciever/dryer???looks like a cylinder with a sensor on top???mounted almost under a battery
Old Jun 28, 2003 | 08:24 AM
eclypsecl's Avatar
that's the one, i need to install a new one..but where do you put the lubrication and everything...because when mine exploded it leaked oil UP. How does the lubrication work..etc
Old Jun 28, 2003 | 09:59 AM
tattoo's Avatar
you should take it to a professional to work on your a/c system you need the proper equipment to vacuum the system and charge it with freon and a proper amount of oil although,most likely you dont need additional oil..
Old Jun 28, 2003 | 10:01 AM
eclypsecl's Avatar
there's plenty of oil that popped out..on air box..on radiator..lots of parts.:-D...yah but i guess i want to save on labor by removing/installing the parts..and they can do the rest..
Old Jun 28, 2003 | 11:24 AM
tattoo's Avatar
most likely the new part comes with oil already.if you mess it up,you'll have to spend more money than anticipated.just my 2 cents hope it works out.
Old Jun 28, 2003 | 11:31 AM
eclypsecl's Avatar
does anyone know, vacuuming comes before or after the accumulator/filter is on.
Old Jun 28, 2003 | 11:53 AM
tattoo's Avatar
after everything is assembled together.vacuuming is done to boil moisture out of the system.should be done for at least 20 min.
Old Jun 28, 2003 | 11:56 AM
eclypsecl's Avatar
so basically aside from changing accumulator, i won't have to do anything..they'll just have to boil/fill with coolant? wonder how much $ that will save me
Old Jun 28, 2003 | 01:47 PM
tattoo's Avatar
about 50-60 bucks i guess
tsi6001
Oct 3, 2022 10:23 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Sep 22, 2015 04:22 PM
A32goldylocks
Sep 2, 2015 06:39 AM
erniel
Aug 8, 2015 09:32 AM
