Rough idle/stall
Rough idle/stall
Whats up, my check engine light turned on and my car was like when i had it on Drive or Reverse it would idle smooth but at times it would give me a lil shake and the rpm drops to like 650-600. then sometimes i accelerate the car slowly and at 1500-2500 rpm it shakes like its about to shut off. and when im on WOT on 3000-4000 rpm it like loses power then gains it right back after dat. so i took it to the shop and they said my front o2 sensors needed to be changed.i went to a nissan dealer and changed both of the front ones and the check engine light came off.but i still get the problem at idle sometimes. and like at 1500-2500 rpm it still does it but doesnt do the higher rpms. i was told it could be misfire on one of my plugs. PLEASE help me guys my first max and i really want to keep it.thanx
its either your spark plugs or ignition coils.
if its your ignition coils, the ecu will throw a code, as to which cylinder is misfiring.
otherwise one or some of your spark plugs can be fouled.
if its been awhile, its good to change them (not that expensive anyways)
dank4us
34
06-10-2024 03:45 AM
litch
123
01-04-2024 07:01 PM
CorollaULEV
30
08-09-2021 08:11 PM
ballerchris510
09-10-2015 09:35 PM
