95 Max, wheres the EVAP, not by the rear wheel.
Old Jul 3, 2003 | 04:03 PM
bobjohnson's Avatar
Blazin......
I cant find the EVAP cnaister purge control valve. "OR" . EVAP canister purge volume control.
Its not on the top of and engine and its definatley not in a box near the rear wheel either. HELP! i got a box by the rear wheel but its just a vent that goes into the trunk (i took it off a few times, i know) Also Why do 97-99 have all that stuff at the top of the engine?
any help is appreciated.
Old Jul 3, 2003 | 04:36 PM
sandman1098's Avatar
Im looking in the Haynes Manual, and on the very last page of Chapter 6, there is a picture of the location of the Charcoal canister. It is under the ductwork for the intake. pretty much between the Throttle Body and Air Filter housing. Just remove all that ductwork and look down in there between the 2 above mentioned parts, towards the brake lines. On the 95's, its a round canister instead of a box. I hope this helps
Old Jul 3, 2003 | 06:50 PM
bobjohnson's Avatar
Blazin......
thanks. i already know where the evap canister is but its not the problem.
Wheres the Purge valve control selenoid
Or the volume control.
Heres a link to a FYI. this is a 97-99 car, Mines a 95
Any ideas as to where its at< ANY IDEAS.
http://www.cybrrpartspro.com/Chilton...61CH04_33.HTML
Old Jul 3, 2003 | 06:54 PM
bobjohnson's Avatar
Blazin......
bump this
Old Jul 3, 2003 | 07:35 PM
My mistake......
Old Jul 3, 2003 | 08:10 PM
bobjohnson's Avatar
Blazin......
its cool , any idea guys i cant find it... not behind the back wheel either
Old Jul 7, 2003 | 03:39 PM
bobjohnson's Avatar
Blazin......
bump again...
Old Jul 7, 2003 | 06:36 PM
bobjohnson's Avatar
Blazin......
bump.
Old Jul 8, 2003 | 04:52 PM
Neptune97's Avatar
I think I've pulled the EVAP purge valve ECU code before, and attempted to find and fix it. I think, although I'm not positive, that the purge valve is the small cylinder shaped object that bolts directly to the large black shoebox located behind the driver's side rear tire. It faces the front of the car. No idea if that's right, however, cause I was never able to fix it.
Huttig2009
Sep 25, 2015 03:31 PM
02nissmax
Sep 5, 2015 01:50 PM
lux97Max
19
Aug 27, 2015 07:48 PM
doobadoo
Aug 15, 2015 06:43 PM
