Plug Removal 97
Old Jul 6, 2003 | 03:47 PM
rhonster's Avatar
Plug Removal 97
how do you get at removing the coil to change the rear plug on the drivers side.
what has to be removed and how do you get at it? is there photo instruction site somewhere?
Old Jul 6, 2003 | 04:11 PM
Klamathvx's Avatar
It's actually pretty easy.
The coil for cylinder 5 (driver's side rear) is located here:
When viewed from above, you will see:
Simply unplug the grey connector on the coil, then remove the 2 hex/phillips screws holding it in. That will expose the plug bore.
Removing the plug can be a doozy. I had to use a long extension and an angled adapter on my ratchet to get it out.
Hope this helps!
Old Jul 6, 2003 | 04:34 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: Plug Removal 97
here is a great write up here
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
