y-pipe gaskets and bolts
Old Jul 7, 2003 | 01:11 PM
joew's Avatar
I just received my budget y-pipe today. There are 3 gaskets total and 2 are metal gaskets… shouldn’t that come with paper gaskets as well. Inside of the pipe has lots of dirt. Should I try to clean it? Where can I buy a few new bolts?
Old Jul 7, 2003 | 02:31 PM
Dreizehn's Avatar
Re: y-pipe gaskets and bolts
There should be two crush rings and one gasket if I remember correctly.
The crush rings go inbetween the Y and the exhaust manifold and the other gasket goes between the cat and the Y.
Old Jul 7, 2003 | 08:11 PM
joew's Avatar
so those are crush rings.. ok thanks.
what about in the pipe. it has lots of dirt. do you try to clean it?
is there a web site where i can buy some bolts.
Old Jul 7, 2003 | 08:48 PM
speedemn's Avatar
The dirt would be blown out of your exhaust when you install it and start the car up... I wouldn't worry. It wouldn't hurt to shove some compressed air through there to flush it out.
As for bolts, your local hardware store is probably easier and cheaper than buying off a website. Heck bolts are cheap enough... just get the right kind from Nissan.
Old Jul 7, 2003 | 10:59 PM
maximaseefu's Avatar
Old Jul 8, 2003 | 01:25 AM
Max Noob's Avatar
the 6 studs for the manifold are about 2.16 a piece from nissan.. the nuts are 4.00 from nissan.
cat nut is .60 cents.. cat bolt is 1 buc and some change.
i checked it out today.. just go to pepboys and get the cat bolts and nuts. studs u prolly wont be able to find so go to nissan for those. then go to pepboys or home depot and get soem ss nuts that fit the studs if you wanna replace alll the mounting hardware.
Old Jul 8, 2003 | 09:56 AM
joew's Avatar
thanks all.
litch
123
Jan 4, 2024 07:01 PM
Quickywd01
Sep 21, 2016 09:36 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
