Nightrider's automagic......!!!
Originally posted by Weasel
Someone want to explain how a Supra differential can fit in a Maxima's transmission? Or why an existing Maxima LSD wouldn't have the been the glaringly obvious choice? Or why a Supra can have Positraction (NOT just any LSD) in the first place? Or how all of these mods together will get a 4th gen to 13.6 without tearing off body panels?
Stock gear ratio is 3.20, not 3.62.
Other mods include:
Custom short ram intake (filter sits behind the headlight)
Budget y-pipe
Pilot Motorsports canister muffler
UPRD ECU
Port matched upper and lower intake manifold and throttle body
Extrude honed exhaust manifold.
Yes, the stock maxima clutches only have 7-teeth. This equates to a 3.20 final drive. My new clutches have 15-teeth. This equates to 3.85 final drive.
This is in accordance with Jatco, the makers of this transmission.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Nightrider's automagic......!!!
Originally posted by kwamdoo74
First of all when you did the car test did you take in account the aftermarket mods that he has. One being a specially designed intake. Second he has an ecu. Third, he has had his manifold worked on as well. If you have all of these factors programmed in, then let me know. Also, eventough your program can simulate it, I bet your car can't do it. Especially on the road as I said earlier. Your car will shift gears in "D" well before you hit 6600 rpms.
If a car has a xxx final gear and xxx gear for each one of the gears, no mods will really allow it to run any higher speed in each gear. Maybe if the redline is raised though the ecu? But mods like Y, intake, muffler will only allow the car to get to xxx speed quicker than before. But with xxx final gear, xxx gear ratio and xxx rpm, the speed will be pretty much constant w/ the same dia tires.
And if the Supra differential is a true LSD unit, it won't "lock". The % slip that it allows is probably much higher than a VLSD as most non-vlsd units are above 25%. But the Quaife would have been a good canidate vs the Supra unit.
Only a welded up differential will 100% lock. Not good for street use at all.
PharoNDmist
Nov 13, 2002 05:54 AM
kwamdoo74
Sep 11, 2002 05:00 PM
