Cold starting problems??? Help
Hello, I am new here so if this was covered before sorry.
Here goes, 1995 max 123K miles auto, when I go to start it up after it has been sitting more than 20 min it is very hard to get going, or will fire and cut right back out. I have tried 87-93 oct gas no diff, I am thinking maybe the fuel pump but would like some other input??
Will
Will
Re: Cold starting problems??? Help
Will
Will
lol...j/k!OK, bad cold start problems are probably related to the Engine
Coolant Temperature Sensor (ECTS) which mixes the air/fuel depending
on the sensor's reading.
BUT, you'll have to be a bit more specific...it starts, then quits...
Does it ever work? It must if you can let it cool down for a while!
so, be more descriptive.
PLUS -- to avoid getting flamed on here -- USE THE SEARCH FUNCTION
on the top right of your screen...it is your best friend.
take care and good luck!
FLO_BOY
First try cleaning your throttle body. Go to www.motorvate.ca for detailed instructions. If that doesn't cure things, definately look into the Engine Coolant Temp sensor as Flo-Boy suggested.
tsi6001
Oct 3, 2022 10:23 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
