5 speed question..
Old Jul 8, 2003 | 09:58 PM
dss42's Avatar
5 speed question..
I just did a conversion from auto to 5 speed and Here is a list of problems I am having :
1. My car was running fine when I was auto when they finished conversion I took car home was all fine except the vibration.. All of a sudden my check engine light went on I went back to the shop he says its Knock Sencer I did the door trick clicked it 5 times check engine went away but I still ordered the Knock senser since then my car has really been hard to start sometimes wont start at all just makes the noice like the battery is dead (My Battery is fine) went to another shop says you need to change engine harness to the one they have in manual cars like $1200 I dont get what engine harness has to do with my car not starting right I mean if it worked when I was auto what is the problem when its manual Do you think its because of the knock senser or ignition problems please help I really love 5speed but cannot drive when I know something is wrong with my car.
2. Car shakes when going in first gear (vibrates) really hard everyone says its your ACT clutch ones it brakes in should be fine 128k so far problem still not gone. Same problem when going reverse also shakes.. When I give it high RPMS like 3k the car wont jerk but thats crazy my friends 5 speed does not have that kind of problem is this really the clutch or??
Thanks in advance.
Old Jul 8, 2003 | 10:24 PM
dss42's Avatar
bump
Old Jul 8, 2003 | 10:28 PM
nismos14's Avatar
§è~® f®ÈÄk
the shaking is probably the surface of the flywheel being very rough
Old Jul 8, 2003 | 10:36 PM
dss42's Avatar
I did this at maximum Tunning he says its the clutch and I should give it more gas..
Old Jul 8, 2003 | 10:38 PM
dss42's Avatar
I did this at maximum Tunning he says its the clutch and I should give it more gas.. He is very expirianced with Maximas and I dont think he would just put in the flywheel without examining it.
Old Jul 8, 2003 | 10:39 PM
cscm094's Avatar
At the time of clutch installation, was the flywheel resurfaced? It should have been. Could be causing some problems...
Old Jul 8, 2003 | 10:43 PM
dss42's Avatar
What about my biggest problem the starting?
Old Jul 9, 2003 | 07:30 AM
dss42's Avatar
bump//
Old Jul 9, 2003 | 07:46 AM
96BLUMAX's Avatar
Either a clutch problem or just give it more gas. I know my act shakes the car when i dont rev too much when starting 1st. Thats just the way it is.
Old Jul 9, 2003 | 07:50 AM
dss42's Avatar
does the problem go away after you brake it in or I will always have this?
Old Jul 9, 2003 | 07:54 AM
96BLUMAX's Avatar
well my experience with the maxima and stick is just with a cenerforce clutch and a act. Now i gaurantee no matter how long you drive it, the ACT will always be more rough. Thats just its design so i think that what you experiencing wont go away, unless if there was something wrong with the install, which is unlikely.
Old Jul 9, 2003 | 08:06 AM
dss42's Avatar
Alright now why is my car harder to start now takes 3-6 trys to start it what can be the reoson 97k on it problem started showing up alittle before conversion from auto to stick now after conversion problem is really noticable because it heppens every time.. please help I wanna drive my car already
Old Jul 13, 2003 | 04:30 PM
dss42's Avatar
bump.. took it to the nissan dealership they think its my starter what do you guys think??
* On my passanger side where the computer is there is a relay there my mechanic thinks its because of that anyone have any thoughts..
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
