pcv
Old Jul 10, 2003 | 06:05 AM
fisher01's Avatar
pcv
Its easier to clean the throttle body and change the spark plugs than to change the pcv valve. Took me about 45 min. to change. Maybe the hose on mine was cut a lttle long, because it had absolutely no flex and just would not budge. Once off, only took a few minutes to replace.
Old Jul 10, 2003 | 06:07 AM
fisher01's Avatar
Hmm.. I was replying to the other thread, don't know how I eneded up with a new subject.
Old Jul 10, 2003 | 06:28 AM
mzmtg's Avatar
Minister of Silly Walks
The other thread was locked.
Old Jul 10, 2003 | 06:31 AM
njmaxseltd's Avatar
Remove the bolt that holds the piping to the intake runners. That give you more then enough free play to pull the pipe off the hose and then pull the PCV valve up.
The job takes about 5 minutes.
Old Jul 10, 2003 | 06:43 AM
mzmtg's Avatar
You can clean the PCV with TB cleaner. If you clean it out and shake it, you should be able to hear the valve inside rattling back and forth.
Old Jul 10, 2003 | 07:41 AM
Max96GLE's Avatar
After I changed my PCV valve. My ECL only came on when I started my engine. When I turn my engine off and try to check for the ECL code. The ELC were gone and I didn't get any codes. The ECL comes on and off very frequently and I have no way to checking the codes. Does anyone have that problem? Could it be that the PCV is loose?
Yes, Changing the pcv only took 5 minutes. I just loosening one of the screw and pull the valve and the tube up from the engine all together.
I also clean out the Throttle body intake. Boy! I felt the power that were missing, coming back from the engine. :-)
Maxima 96 GLE
Old Jul 10, 2003 | 07:52 AM
96BLUMAX's Avatar
ECL, ELC, ... CEL?
Old Jul 10, 2003 | 08:22 AM
Bmr4life's Avatar
hey guys, i was thinking about doing these routine things this weekend, cleaning/replacing pcv valve and cleaning the throtle body.
Where should I purchase a new PCV from? Is advance autoparts okay? If so, is there a specific brand I should buy from them?
Old Jul 10, 2003 | 08:45 AM
Maximum96's Avatar
I cleaned my throttle body out but not the pcv valve. i wanted to but a guy at pep boys told me not to,i dont think he knew anything though, is it safe to clean out the pcv valve. i sprayed t b cleaner into the idle air control valve as well, should i spray the pcv valve ???
Old Jul 10, 2003 | 10:04 AM
joew's Avatar
may be you may want to take the idle air control valve apart and clean it.
Old Jul 10, 2003 | 01:11 PM
Bmr4life's Avatar
where is it and how do you clean it?
thnks
Old Jul 10, 2003 | 01:59 PM
Street Reeper's Avatar
Handsome
I was burning oil because of a clogged PCV, d@mn nissan didn't change it for the 60,000 mile service (have to keep a paper trail for 100K warranty, and yes I did bend over and grab my ankles when they gave me the bill) I changed it in about 10 minutes (have some needle nose plyers handy) and everything is fine now.
Old Jul 10, 2003 | 02:47 PM
joew's Avatar
here is the pic.
instruction is on 4 gen faq. good luck.
thnks
Old Jul 10, 2003 | 04:54 PM
Bmr4life's Avatar
thank you for the pic
bumpypickle
Sep 20, 2015 08:22 AM
lowpost99
22
Sep 2, 2015 04:38 PM
maxinout93
Aug 20, 2015 02:17 AM
puch
Feb 25, 2002 03:28 PM
Dave B
Aug 28, 2001 09:47 AM
