NGK Platinums causing loping idle?
Old Jul 10, 2003 | 12:42 PM
BlackCat's Avatar
RIP '98 Maxima SE
A loping idle (as described by the Haynes manual) is where the idle speed goes slightly up and drops down and I've been having this for quite some time. I've read that the NGK Platinum spark plugs come pre-gapped and so I put them in a while ago.
Now the manual says that there are other things to check out but could the spark plugs be the culprit here?
Old Jul 10, 2003 | 01:18 PM
njmaxseltd's Avatar
Spark plugs generally will not be the cause of a loping idle speed.
Clean your throttle body
** Clean your IACV (IDLE AIR CONTROL VALVE)** - controls idle speed
Check/clean or replace your PCV valve
Old Jul 10, 2003 | 01:39 PM
BlackCat's Avatar
RIP '98 Maxima SE
Hmmm...I've already cleaned the throttle body, fiddled with the idle speed control...all thats left is the PCV...Thank you!
Old Jul 10, 2003 | 02:22 PM
icheban26's Avatar
can u tell me where the IACV is...n how can i go about cleanin it???
thanks
icheban26
Old Jul 10, 2003 | 02:26 PM
Jeff92se's Avatar
I'm needing a caw
You can try unhooking one coilpak connector at a time to see if the idle changes or not. If it doesn't change, that is your cylinder. Bad plug, bad connection or bad coil pak.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
