Brake Problem: Irregular Pad Wear
Old Jul 12, 2003 | 07:12 AM
95GreenGLE's Avatar
Here is my problem. On my drivers side only, the pad on the outside of the rotor was COMPLETELY gone, and all the other pads (drivers side inner, and both passanger side pads) still had more than 50% left on them.
When i drive, it seems like the pad is not releasing back from the rotor when i stop on the brakes.. but does not make the car pull to that side when braking, it only seems to pull (noticably) when at highway speeds (60+)
Is my caliper frozen/bad? Is there something i can do to loosen it up? Or do i just have to replace it? Maybe some grease would help?
Any input would be greatly appreciated. thanks in advance
-Nick
Old Jul 12, 2003 | 02:32 PM
95GreenGLE's Avatar
Bump
Old Jul 12, 2003 | 02:58 PM
Nismotic's Avatar
Always sunny in philly
check your rotors. most of the time that is the cause of brake wear problems. The more "grooves" you have over the surface, the more irregular wear you will have.
If thats the case and you need new rotors, go for the brembo drilled rotors.
Old Jul 12, 2003 | 03:54 PM
TooMAX's Avatar
Re: Brake Problem: Irregular Pad Wear
-Nick
Sounds like you caliper pin is stuck. There's a whole brake job how-to Here at Motorvate. About the middle of the second page he talks about caliper pins.
Old Jul 12, 2003 | 05:50 PM
kushane's Avatar
Re: Re: Brake Problem: Irregular Pad Wear
This seems to be the likely scenario. Make sure you remove the caliper pin boot, (I turn it inside out and clean it properly), and clean the pin and lube it with grease. Basically make sure that the caliper can "float" freely when you move it inside/out.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
