jerking and slight hesitation
Old Jul 15, 2003 | 09:00 PM
nismos14's Avatar
§è~® f®ÈÄk
i get some jerking in my car when i let off the gas going about 10 mph in 1st gear, sometimes i'll let off the gas and it will roll a bit then suddenly jerk while still rolling at like 3-4 mph, also i get some slight hesitation when accelerating in 2nd and 3rd at about 2200 - 2500 rpms, wtf is the problem? PlSSIN me off! lol
Old Jul 15, 2003 | 09:04 PM
humberto_i30's Avatar
My '96 I30 is doing exactly the same, what can it be ? I'm afraid to take it to the stealership, they will end up changing everything and leaving my checkbook empty !
Old Jul 15, 2003 | 09:08 PM
nismos14's Avatar
§è~® f®ÈÄk
is it just doing the hesitation or in first gear too? are u 5 speed or auto?
Old Jul 15, 2003 | 09:20 PM
mine is auto and doing it in first and second gear ! between 2000-2500 rpms !
Old Jul 15, 2003 | 09:38 PM
infinitiman96's Avatar
your definition of "jerking" is pretty vauge, but it sounds like an engine mount
Old Jul 15, 2003 | 09:41 PM
nismos14's Avatar
§è~® f®ÈÄk
hmm well its like i'll take it up to 10 or so mph in 1st, and let off the gas and it roll a little bit then the car will bog, like if ur not giving it enough gas off the line and letting off the clutch too fast almost abou to stall, but not quite that violently
Old Jul 15, 2003 | 09:59 PM
Just pulled out codes on mine and threw 0304 (Knock Sensor fault) ! Check engine Light is not ON, never has been ON !
Old Jul 15, 2003 | 10:09 PM
nismos14's Avatar
§è~® f®ÈÄk
i dont get KS code when i check, im gonna check it again soon
Old Jul 15, 2003 | 10:12 PM
I think that I already found the problem (Knock Sensor), will replace mine soon and post results here, www.motorvate.ca is a great site as a guide to replace the knock sensor (expensive part, $124.99 plus shipping)
Old Jul 15, 2003 | 10:50 PM
Chino's Avatar
Either that or its the good ol' Autotragic transmition of ours. It sounds like my car. Except my car is perfectly fine. On let me guess, does it lag in 2nd gear up until you hit 2k RPM? Where you get a sudden boost of power? Yeah its just our nasty Auto Transmition.
Old Jul 15, 2003 | 10:56 PM
nismos14's Avatar
§è~® f®ÈÄk
<----- 5 speed
Old Jul 15, 2003 | 11:05 PM
Chino's Avatar
Originally posted by nismos14
&lt;----- 5 speed
Rub it in our faces why don't cha?!?!
If only I would have known what I know now then.
How much is the conversion process by a transmition shop? Oh, never mind I'll search before I get flamed. Thanks.
Old Jul 15, 2003 | 11:08 PM
nismos14's Avatar
§è~® f®ÈÄk
lolz 1500 on the cheap side can range up to 2500, and i feel the same way about my old 240, if i had just known i NEVER would have gotten it in auto GRRRRRRR
Old Jul 15, 2003 | 11:29 PM
dantheman598's Avatar
ive got that same sorta problem, feels like the transmission is falling out of the bottom of my car sometimes when it shifts, especially 2nd-3rd around 2500-3000 rpm. and mine gets that "extra boost" like you were talking about around 2750 rpm, kind of strange. feels like it downshifts, but its just accelerating, and then actually shifts so its a pretty jerky ride
Old Jul 16, 2003 | 07:49 AM
s0ber's Avatar
we got a weak turbo that spools up at 3k then we get our maxima boost Damn autos...
Old Jul 16, 2003 | 07:12 PM
nismos14's Avatar
§è~® f®ÈÄk
bump
Old Jul 16, 2003 | 07:44 PM
dss42's Avatar
Wow man I just did a conversion about week ago while driving today I let it roll in first gear like 10mlp and it started jerking my check engine light also shows knock sensor will that fix the problem? Why did knock sensor come up after conversion ?
Old Jul 18, 2003 | 02:59 PM
nismos14's Avatar
§è~® f®ÈÄk
figured it out im such a geek, if u have a midpipe make sure u do this, there should be a lil hole in it that allows u to place the intake air temp sensor from the scoop that goes to the air box in stock trim, onto the midpipe, i plugged it in, hesitation is GONE..... now i have a knock sensor code tho i reset it and it hasn't come back.... will it come back if its bad? will it NOT come back if its bad since i recet it?
Old Jul 18, 2003 | 03:19 PM
If the knock sensor is bad the code will come back and the ECU will register it again in memory !
Old Jul 18, 2003 | 03:23 PM
nismos14's Avatar
§è~® f®ÈÄk
ok good so if it doesnt come back then the ks is ok?
Old Jul 18, 2003 | 08:59 PM
dss42's Avatar
Damn knock Sensor cost me $165 it is the size of a small screw.
Old Jul 19, 2003 | 11:09 AM
Mine costed me $129.00 including shipping from www.bestforeignparts.com !
Old Jul 19, 2003 | 11:21 AM
dss42's Avatar
damit wish I had that link before.
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
