WHERE is the knock sensor?
Old Jul 16, 2003 | 10:20 AM
I H8 COPS
Can anybody tell me where exactly the knock sensor is on a 5-spd 99 SE-L? Also, what does the knock sensor do? And why is it called knock sensor...any particular reason? Does it make a knocking noise when defective by any chance?
Old Jul 16, 2003 | 10:27 AM
njmaxseltd's Avatar
It's under the intake runners closer to the drivers side of the car.
If your a cali spec, you woun't be able to see it because it's view is blocked by the swish valve actuator.
It's called a knock sensor because it detects engine knock caused by detonation. Once it detects knock, your cars ECU will adjust the timing to make the knock stop. Knock = BAD
Old Jul 16, 2003 | 10:28 AM
FLO_BOY's Avatar
Re: WHERE is the knock sensor?
go to my website -- click on "Help with Maximas" and I have a few
pics of what the KS looks like, and where it is on your engine...
as for what it does, you can use the SEARCH or:
-- Knock Sensor checks for engine knock.
-- Knock is caused by using bad gas that detonates too early.
Early detonation is usually caused by too low an octane.
-- when knock is detected, the engine changes it's timing to
compensate for the knock, and will rob you of power.
-- when defective, you get a code...or you can use an altimeter
to find out if it's bad.
that's off the top of my head...don't quote me on that stuff either.
good luck!
FLO_BOY
Old Jul 16, 2003 | 11:06 AM
LiquidNine's Avatar
from motorvate.ca
Old Jul 16, 2003 | 11:41 AM
ejj's Avatar
ejj
Black thing in the middle:
Old Jul 16, 2003 | 03:46 PM
BatKeith's Avatar
Flo_boy, that's a sweet ride you have there.
Old Jul 16, 2003 | 03:52 PM
FLO_BOY's Avatar
thanks man!!!
FLO_BOY
Old Jul 16, 2003 | 04:02 PM
Scruit's Avatar
U wanna try me young boy?
You can test the knock sensor with a Volt-Ohm meterm or multimeter.
An altimeter is the guage that tells you at what altitude your plane is flying.
Old Jul 16, 2003 | 04:05 PM
FLO_BOY's Avatar
uh, right.
just trying to keep everyone on their toes
FLO_BOY
Old Jul 17, 2003 | 10:48 AM
Scruit's Avatar
Would even funnier if I was up in the Cessna, and my altimiter read 470k Ohms.
Old Jul 17, 2003 | 01:36 PM
mAxPwEr4Us's Avatar
taking the KS out of there is realy easy.... it took me like 2 mins to do it.. but what i can't do is is unplug the harness of the damn KS... any ideas how to do that??? please help
Old Jul 17, 2003 | 01:43 PM
ejj's Avatar
ejj
There is a 'U' shaped metal clip that goes around the wiring harness. You need to pull that off with a pair of pliers (or something) to get the harness off.
Old Jul 17, 2003 | 01:44 PM
FLO_BOY's Avatar
mine just unclips...
FLO_BOY
Old Jul 17, 2003 | 02:23 PM
mAxPwEr4Us's Avatar
OHhh that's how you do it... lol thank you very very much for the help
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
