View Poll Results: After how many miles did you have to replace your OEM clutch?
< 100,000
27.59%
100,000 ~ 150,000
41.38%
150,001 ~ 200,000
20.69%
200,001 ~ 250,000
10.34%
Voters: 29. You may not vote on this poll
After how many miles did your OEM clutch wear out?
Old Jul 18, 2003 | 04:05 PM
Gary95's Avatar
This is just about the Nissan OEM clutch. At what point did you experience sufficient clutch slippage to warrant a new one? Was it a very gradual wearing out or did the clutch suddenly start noticeably slipping?
I'm at 132k and my clutch still feels strong. I can get it to slip a little at WOT in 3rd when it's very cold out, but that's about it.
Old Jul 19, 2003 | 05:39 AM
Carlbz's Avatar
Clutch
I just replaced my clutch in my '95 two days ago, at 108K. Surprisingly, there was still plenty of friction material left on the disc! It failed when the rivets that hold the disc to the hub sheared off, causing the disc to just flop around in the transmission. I had replaced the axles and put some new tires & wheels on the car a week prior to the clutch's demise, and suspect that the clutch became the "weakest link" afterward.
It's the story of my automotive life; I repair or upgrade one component, and open up a Pandora's box of other problems!
Old Jul 20, 2003 | 08:44 PM
Gary95's Avatar
Re: Clutch
Originally posted by Carlbz
I just replaced my clutch in my '95 two days ago, at 108K. Surprisingly, there was still plenty of friction material left on the disc! It failed when the rivets that hold the disc to the hub sheared off, causing the disc to just flop around in the transmission. I had replaced the axles and put some new tires &amp; wheels on the car a week prior to the clutch's demise, and suspect that the clutch became the &quot;weakest link&quot; afterward.
That's weird, the rivets getting sheared off like that. You're lucky the drivetrain didn't seize up on you!
Well, as they say "if it ain't broken, don't fix it"; but my take is that if you follow that, you'll be faced with a ton of things to do all at once one day. Better to ease into it, little by little.
I wouldn't be surprised if someone has published guidelines for the "die hard high mileage owner", outlining the typical things that wear out that should be inspected or replaced. It's amazing how many things can wear out on a car, although these days the lifespan of components is quite longer. Bottom line--if you don't perform regular servicing, parts begin to wear faster, and one bad part can force others to prematurely wear.
Old Jul 20, 2003 | 09:45 PM
nismos14's Avatar
§è~® f®ÈÄk
95 k as far as i know it was the stock clutch in there, now i hve a POS clutch and cant' wait to get it out
Old Jul 21, 2003 | 03:01 AM
Max Noob's Avatar
111k and counting.doesnt slip yet but catches kinda slow.. did the 5th gear at 30mph and punching it cluth test and it holds fine..oem clutch rocks..
Old Jul 21, 2003 | 05:33 AM
maximachad's Avatar
Lifetime Maxer
Yeah, I'm at 124K here on original clutch - still grabs beautifully. No slipping at all.
Chad
Old Jul 21, 2003 | 05:52 AM
maxfreak_98's Avatar
Re: After how many miles did your OEM clutch wear out?
I'm at 101K on my original stock clutch without any signs of wear. This is also after about 70 or so runs down the track and some occasional spirited in-town driving.
It's the one thing on my car that I would use a stock part to replace.
Old Jul 21, 2003 | 08:28 AM
Dave B's Avatar
Not DAVEB the parts guy
Almost 98K miles on my OEM clutch and it still grabs very hard with no signs of slippage. I also have about 3 years of 1/4 mile racing on this clutch with ~30 passes. Around town, I do romp on it a bit, but it is rare that I ever slam the 1-2 or 2-3 shifts. There's just no need unless you're racing against a clock.
I think the things that kill clutches quickly are:
1) Clutch dump launches
2) Constant hard shifts
3) High rpm clutch slippage during racing
4) Overall inexperience with a manual tranny
At the track, I launch at 3500-4000rpms with just a little clutch slippage to get rolling and then I quickly let up the clutch (no dumping) and feed the car some gas. This usually results in mid 2.2 60 foots.
I'm very impressed with the OEM clutch and I'd be a fool not to go with it again. Every once in a while the clutch gets some chatter (cold humid days) and sometimes it's hard to leave from a stop smoothly, but numerous magazines have noted this and my car has done this for 5 years so I'm not worried. I've been expecting my clutch to die for about 1 year because of my 1/4 mile racing and the fact that my car is making 25% more power than stock. When it finally dies, I won't be disappointed because it's had a very hard life and it served me well.
Dave
Old Oct 28, 2003 | 08:25 AM
MrEous's Avatar
^ Jeff™
Isn't this poll the same as:
http://forums.maxima.org/showthread.php?t=258908 <---that poll?
Old Oct 28, 2003 | 08:27 AM
mo'max's Avatar
OEM Clutch life
I have 155K on my 95SE which includes a modest amount of spirited driving. It still feels strong, but I've never had a clutch last this long. Out of pure paranoia, I've decided to replace it today with another OE clutch. No Bill yet but the estimate is $800.
Old Oct 28, 2003 | 07:34 PM
95MAXIMASExy's Avatar
150xxx miles on mine no problems. hope to get at least 200k out of it
Old Oct 30, 2003 | 04:31 AM
mo'max's Avatar
Final Bill $860 ($230 parts).
Old Oct 30, 2003 | 02:12 PM
ORBRIT's Avatar
dang where did you get it replaced?
I paid $417 for my OEM replacement including labor.
Old Nov 3, 2003 | 05:17 PM
Porcupine's Avatar
Can someone give me a link to or tell me about this test. I'm at 82k on my clutch and have my doubts about how good of shape it is in.
Old Nov 27, 2003 | 05:43 PM
meccanoble's Avatar
Sports Button FTW
i'm at 143k on original clutch. No slipping unless under XTREME conditions (super spinning in first then hard shift into second after redlining)
Old Nov 27, 2003 | 06:52 PM
mrglynis's Avatar
I've only got 66k on mine. Feels fine. I do have 1 question though. I get clutch chatter occasionally. Dave B mentioned it happens to him too. What exactly is it? He said it had been going on for years. I take it , its not a serious issue then? Just curious. I've never had any other clutches chatter. Thanks for info you can give.
Old Nov 27, 2003 | 06:57 PM
cydrive's Avatar
150k on mine. Bought the car with 68k and as far as I know, still the original OEM clutch!
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
MikesChevelle
Aug 10, 2015 10:53 AM
