Cleaned up the MAF with alcohol
Old Jul 22, 2003 | 12:16 AM
chris j vurnis's Avatar
I decided to be adventurous with my MAF. I took it out and scrubbed off all the dirt on the inlet screen. I wiped out all the dust particles on the interior of the MAF. Then I sprayed isopropyl alcohol on the sensor element getting them nicely soaked and waited for it to dry. Then I reinstalled the sensor.
The bottom end acceleration is nicely improved. Moderately more forceful off the line and it goes through the dreaded 2000-3000rpm dead spot noticeably better. There is a bit better throttle response cruising on the highway in overdrive at 70+ MPH.
I have a K&N filter so I thought it would be a good idea to clean up any residual oils that may be on the sensor element. A technician at one of the local speed shops here recommended the same procedure to me.
I rinsed out an empty bottle of windex glass cleaner and filled it with isopropyl alcohol for the cleaning task. Alcohol evaporates fast and lifts off oils much faster than water.
I think maybe I might spray the whole K&N panel filter with alcohol to remove the oil on it. It is not very saturated right now but I remember it being a lot more greasy when I first installed it.
Old Jul 22, 2003 | 05:37 AM
njmaxseltd's Avatar
Use the K&N filter recharge kit. Your idea may work just fine, but the kit is made specifically for cleaning that filter effectively without harm to the media.
Old Jul 22, 2003 | 06:12 AM
Maximum96's Avatar
No one out there thinks cleanin the sensor with alcohol in the MAF will ruin it??MAybe i will also clean it to get my 2000-3000 up a little more
Old Jul 22, 2003 | 09:01 AM
mzmtg's Avatar
Minister of Silly Walks
Isopropyl (sp?) Alcohol is comonly used to clena all kinds of electronic devices. As long as you are careful not to physically damage the sensing element, it should work fine.
Old Jul 22, 2003 | 09:12 AM
njmaxseltd's Avatar
I use Throttle Body cleaner to clean the MAF when I clean my TB.
Old Jul 22, 2003 | 09:16 AM
Jeff92se's Avatar
I'm needing a caw
I used alcohol and a Q-tip to clean the maf wire. Carefully though!
Old Jul 22, 2003 | 11:45 AM
Jime's Avatar
I have been using Isopropyl Alcohol for a year or so on my MAF and it works great. Make sure you use 90% or purer, it drys faster and has less impurities.
Put the MAF in a ziplock bag and use enough Isoprop to just about cover it and gently shake the bag back and forth to allow the alcohol to pass through the sensor. Take it out and let it air dry or use very low pressure air to dry it off.
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
