Whats up with my alignment?!?!
When I first purchased my max I noticed that it pulled to the left. I figured my alignment was off. After my wife had her fender bender I had to get an alignment done, but the car still pulled to the left! Well now I put in my KYB and H&Rs get it aligned and it still pulls to the left! Not just a little bit either. I think and repeat key word think that my car is aligned but I have to hold my steering wheel to the left a bit. Could my steering WHEEL be of alignment while my actual wheels are fine?
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
Hmmmm....
Originally posted by njmaxseltd
Rotate your tires. If your running non directional tires, swap the left and right front tires and see if the car still pulls or if the pull follows the tire.
A radial pull from your tires will cause your steering to be slightly off center. When I purchased my Sumitomo HTR+ just a month ago, they pulled to the right slightly. I swapped left and right sides immediately and the car runs straight as an arrow.
Directional tires can only rotate in one direction. There marked with an arrow indicating the direction of rotation. Directional tires are usually higher rated performace tires such as low profile Z rated summer only tires. You can't swap left and right side tires if your running directional tires because you wind up with tires rotating the wrong way.
Do you have a printout of your last alignment readings? If you do, post the camber, caster and toe readings.
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
radial tires
are known to drag your car to one side. Try to keep a constant speed and cruise down the road. If the car doens't pull to either side, it's your radial tires.
And for alighnment, may I suggest life time alighnment from Big 10 Tires. $99.95 for computerized alighnment for as long as you own that car.
And did you know that wheel balance gets messed up every 6000 miles? I recommend you buy tires from Discount Tire Co, they give you free balance for as long as you have the tires.
DC_Juggernaut
09-28-2015 04:07 PM
