Coolant Change?
Old Jul 25, 2003 | 03:00 PM
simssims's Avatar
Coolant Change?
It's time to change the engine coolant.I read the post on motorvate.ca and was told I need to open the "valve" in the heater core, to allow the coolant to drain out of it. And There are two way to do this, depending on the type of climate control you have. Is that special only for the Maxima?
Also this is my first time to change the coolant, pls give me some suggestion?
Thanks a lot.
Old Jul 25, 2003 | 07:43 PM
d_hammmer's Avatar
If you have automatic climate control (ie you set a specific temp on the heater/AC) use the directions in motovate.ca to open the heater valve. If you have a manual heater/AC system, turn the heater temp selector to the maximum hot setting, and select heat through the dash vents to open the heater valve.
You'd probably want to run a cleaner in your coolant prior to flushing out the old coolant to ensure you get all the rust and scale out of the system
Old Jul 26, 2003 | 05:36 AM
zagato27's Avatar
Originally posted by d_hammmer
You'd probably want to run a cleaner in your coolant prior to flushing out the old coolant to ensure you get all the rust and scale out of the system [/B]
Don't forget the "Water Wetter". Cheers
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
msellas
Sep 23, 2015 09:16 PM
bumpypickle
Sep 20, 2015 08:22 AM
