Reverse Glow Gauges Install
Old Jul 29, 2003 | 11:41 AM
tszymans's Avatar
Well I tried searching on the new test site for this but I couldn't come up with anything after like 20 minutes, so I'm just gonna post. Does anyone know of an guide to installing aftermarket gauges, specifically the dissasembly of the dash/gauge pod? It would help greatly. Or if someone feels like describing the steps that would also help, but pics would be great. Thanks.
Old Jul 29, 2003 | 01:30 PM
tszymans's Avatar
or is it just pathetically easy and I'm just being stupid??
Old Jul 29, 2003 | 05:32 PM
SuperChris's Avatar
Infiniti 35 Double G's
Try these...however, the instructions look like they're for a 3rd Gen.
Old Jul 29, 2003 | 05:53 PM
Nismotic's Avatar
Always sunny in philly
they are a pain in the butt. my advice is to get someone that really knows how to do it. I had them on for a long time and none of my needles worked. So...i ALWAYS had a full tank of gas...and i was always going 60mph....in park.
Old Jul 29, 2003 | 06:00 PM
tszymans's Avatar
that guide is perfect....thanks. One thing I've learned from a friend and a few posts on the org is NEVER take the needles off. BUt that guide is great. Thanks again!
Old Jul 30, 2003 | 08:11 AM
StygianMax's Avatar
Cheston put those instructions together some time back for his 4th gen. I followed them to install my gauges on my '97 SE last weekend & everything turned out pretty good. I do have a couple suggestions though:
  • use some white glue at (a) the center of your gauge face (tach & speedo) and (b) the corners. If not, they may lift up slightly & snag the bottom of your needle;
  • sand the bottom of my two needles slightly to increase the clearance with the gauge faces.
  • in following the instructions on that site, I removed a couple bulbs to run the wires through. As a result, the fuel needle isn't lit up. I might tear apart my dash again & try to find a spot to punch a hole thorough to run 2 of my wires & replace the bulb behind the fuel gauge.
  • and here's everything all finished up:
Old Jul 30, 2003 | 10:31 AM
tszymans's Avatar
StygianMax
Okay, thanks for the tips. A bit off the subject but how do you like your AGX/Progress combo?? I'm thinking about getting that for myself, just wondering what the ride is like and how you like the drop? thanks.
Old Jul 30, 2003 | 10:41 AM
HuliganRS's Avatar
Why don't you drill a hole to push the wires through?
Just drill from the back so you don't damage the leads...
Old Jul 30, 2003 | 11:12 AM
StygianMax's Avatar
I looked for about 2-3 min. & found that the membrane with the tracks (elec. paths) were spaced pretty closely together. I'' probably take things apart and have a closer look. The hole to be made needs to be ~ 6mm dia. to allow the connectors to pass through. That's why the bulb holes are so ideally suited....sorta.
Old Jul 30, 2003 | 11:17 AM
StygianMax's Avatar
StygianMax
The combo is really good. The Max is very stable on highway sweepers. btw, I have my AGXs set to 3/5 (f/r). I came from SE springs/struts and I noticed quite an improvement in stability. The car just doesn't roll and pitch so much. At the same time, they are pretty comfortable when driving on slightly patchy/rough roads. Though I avoid potholes like the plague. OT: Since I've change my gauges from metric to imperial, driving at 100 seems to be better on my conscience. hehehe.
dcam0326
Sep 18, 2015 04:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
minsbang
Sep 11, 2015 08:48 PM
asianstyle
Sep 10, 2015 11:30 AM
