clutch options
Old Aug 3, 2003 | 09:41 AM
maxdrvr847's Avatar
clutch options
ok im going to install a clutch in the next couple of weeks. I have been told not to go with act due to the chatter and also the problems with damaging transmissions. I have searched and cant find some real opinions as far as other clutch options.
so I need some advise as far as other options, I will just have basic bolt ons so just want a stage 1
1) go back with stock
2) jwt
3) centerforce
4) exedy
5) clutchnet
Old Aug 3, 2003 | 09:50 AM
BoostedED9's Avatar
i am going to be using a spec stage 2 in my maxima in the coming weeks (will be turbo in near future). spec clutches are great, very very soft pedal pressure like stock and great holding power...
Old Aug 3, 2003 | 10:02 AM
maxdrvr847's Avatar
never heard of spec clutches? where can I read up about them or purchase?
Old Aug 3, 2003 | 10:54 AM
BoostedED9's Avatar
you can go to speclutches.com and read up about them... we sell spec at the shop i work at.
Old Aug 4, 2003 | 05:49 AM
maxdrvr847's Avatar
bump
Old Aug 4, 2003 | 06:21 AM
Sprint's Avatar
Re: clutch options
I have an ACT.. i had chatter.. i changed my motor mounts and the chatter went away.. my transmission is holding up fine
make sure you get hte Japanese one.. the key value nissan stock clutch sucks donkey *****
2) jwt
havn't heard much about this..
3) centerforce
buy 3 of them.. because they only last about 10k miles before they start slipping..
4) exedy
i heard its basically an ACT Clutch
5) clutchnet
the only people i know with them are Matt and Sleeper .. they have no complaints.. but they have 6 puk clutches and that might be a bit harsh for you if its only N/A and street use
Old Aug 4, 2003 | 06:22 AM
Sprint's Avatar
Kam your back and with a 4th Gen
Welcome back Buddy!!
Old Aug 4, 2003 | 06:25 AM
maxdrvr847's Avatar
Re: Re: clutch options
[QUOTE]Originally posted by SprintMax
[B]
Did you go back with stock mounts or aftermarket?
Old Aug 4, 2003 | 06:26 AM
Sprint's Avatar
Re: Re: Re: clutch options
poly-filled stock mounts
Old Aug 4, 2003 | 08:39 AM
Abimax95's Avatar
where to get poly filled mounts and how much ??????????
Old Aug 4, 2003 | 08:57 AM
Sprint's Avatar
couple of members here can do them.. also i think instructions might be in the FAQ on how to do them..
ericdwong does them.. matty does them.. and sx7r does them.. its just if they will do them for you... i heard it isn't htat hard.. you just get the stock mounts.. mix the poly and hardner.. maybe more.. and then let them cure..
Old Aug 4, 2003 | 10:29 AM
Jeff92se's Avatar
I'm needing a caw
I would consider getting a Fidanza Billet aluminum 11.8 lb flywheel while your in there. See me sig for details. I had a chance to drive Mtrai's 4-gen w/ the Fidanza and new clutch. Reved real nice. Drivability was excellent.
Old Aug 4, 2003 | 10:52 AM
ejj's Avatar
ejj
Its really not, but its a matter of time. Idealy you'll let the poly set ("dry") for about 4 or 5 days. If you can't be without your car for that long, then you'll have to buy different mounts to use and do them ahead of time.
maxdrvr847, if you're not boosted or using nitrous, get a stock (non key value) clutch. They are more than enough for NA power. There are several members who beat on them reguarly (me, Dave B) at the track and they don't slip.
Old Aug 4, 2003 | 06:24 PM
BoostedED9's Avatar
Quoted Message:
you must have me mixed up with someone else
Old Aug 4, 2003 | 06:38 PM
Dev's Avatar
Dev
Originally posted by ejj
Its really not, but its a matter of time. Idealy you'll let the poly set ("dry&quot for about 4 or 5 days. If you can't be without your car for that long, then you'll have to buy different mounts to use and do them ahead of time.
i agree with that
my stock clutch has 65k km on it...(not much) but its still going strong and has yet to slip
im probably gonna go with a stock clutch when my current one dies.
Old Aug 4, 2003 | 07:07 PM
Sprint's Avatar
yeah i was mixing you up with this guy ...Kam .. the name you are using is his name on Clubsi and other boards
Old Aug 4, 2003 | 07:18 PM
BoostedED9's Avatar
its ok... its prob a s/n similar to mine since i have had this one for a long time in many different boards...
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
Redfox
Sep 28, 2015 10:41 AM
carlosvq30
Sep 26, 2015 09:44 AM
