car back from shop...is this normal?
Old Aug 4, 2003 | 10:29 PM
wrongway15's Avatar
my 98 5spd was in the shop due to loss of pressure in the hydrolic systme...$300 later they replaced the clutch master and slave cylinder and the clutch works now, but it grabs when the peddle is just off the floor and i have to have the peddle to the floor to shift gears...is this bad?
also the peddle is really easy to depress about halfway, then the second half of the way down there is more pressure...is this normal? or bad?
shifter is also much notchier, but i dont think thats a problem
thanks
Old Aug 5, 2003 | 05:58 AM
1996_SE's Avatar
Sounds to me like they just put the catching point of the clutch pedal (where the gears first become connected) near the bottom. This can be easily changed, but I'm not positive that's it...
Old Aug 5, 2003 | 06:40 AM
njmaxseltd's Avatar
Also could be air still in the system.
Old Aug 5, 2003 | 06:48 AM
MAXEJA's Avatar
my guess would be air as well, you have to purge the lines and spill some fluid out.
Old Aug 5, 2003 | 07:56 AM
wrongway15's Avatar
you guys are saying the air in the system is causing the unevenness in peddle pressure? or low catch point?
i thought that may be the case for the uneven peddle pressure
thanks
Old Aug 5, 2003 | 08:25 AM
MAXEJA's Avatar
i have seen on other cars that a low catch point can be adjusted mechanically with like a screw, not sure on the max, but the air should not effect where it grips, thats a ratio somewhere.
Old Aug 5, 2003 | 10:45 AM
time2reup's Avatar
the soft for half and then firm for half definitely sounds like air
Old Aug 5, 2003 | 11:06 AM
wrongway15's Avatar
well i gotta take it back to the shop...its very hard to get into first and hard to shift. i thought i was screwed. i was at a light and it took 3 min to get into gear. i bet some people were ****ed.
Old Aug 5, 2003 | 11:10 AM
azflat4's Avatar
It definitely sounds like air to me too, bleed the clutch, or have the shop that did the work bleed the system, should fix the problem.
-Ryan
Old Aug 5, 2003 | 02:05 PM
nismos14's Avatar
§è~® f®ÈÄk
air definately does affect where it grips, when i bled my clutch and messed up bleeding it, there was too much air in it and it would grab lower so it could definately be part of it
Old Aug 5, 2003 | 02:50 PM
wrongway15's Avatar
well i took it back to the shop and told them what was wrong...they immediately said it could be the clutch. they know i replaced that a few months ago because they tried to get me to replace it the last time i was in with the hydrolic system problem.
they are making me come back in tomorrow morning...seems like they keep mentioning the clutch because they want my $800. i hate ppl trying to screw me.
Lakersallday24
Jun 16, 2019 01:35 AM
egali045
Aug 16, 2015 01:19 PM
acw
Aug 13, 2015 12:50 AM
altome15
Aug 10, 2015 07:05 PM
egali045
Aug 5, 2015 09:02 AM
