MEVI...use a relay, or no?
Old Aug 5, 2003 | 11:55 AM
ejj's Avatar
ejj
I'm going to hook this thing up finally. I vaugly remember relay vs. no-relay threads a while back, but couldn't find them.
Is a relay necessary? Can the Harlen switch handle the ground needed by the MAP (GM) switch?
Old Aug 5, 2003 | 12:16 PM
mzmtg's Avatar
Minister of Silly Walks
From what I can gather, the most relaible method is to use a relay. Run the wires so the relay and the harlan switch are inside the cabin.
Sprint's Avatar
i don't use a relay with mine
Old Aug 5, 2003 | 01:14 PM
I30tMikeD's Avatar
No relay, but I know it's been recomended to use one. No problems with my VI except a bad vaccum canister.
Old Aug 5, 2003 | 01:39 PM
XXXL Cracker's Avatar
No relay here...
Old Aug 5, 2003 | 01:41 PM
ejj's Avatar
ejj
And you no-relay guys are using a harlen?
Old Aug 5, 2003 | 01:52 PM
yes
Old Aug 5, 2003 | 02:55 PM
hacim105's Avatar
no relay and using harlan works everytime for me
have had it on for 3 months now.
Old Aug 6, 2003 | 05:55 AM
guestNX's Avatar
use a relay. there is no reason not to.. it is a couple dollars, and if nothing else, better safe than sorry.
Old Aug 6, 2003 | 06:32 AM
Sprint's Avatar
no relay.. using NOS switch
what safety? what the hell are you talking about
Old Aug 6, 2003 | 06:51 AM
Stephen Max's Avatar
If you pass too much current through the Harlan switch you could burn out a circuit, hence it's safer to use a relay which limits the amount of current passing through it and the Harlan switch.
The reason people are getting away with not using a relay is because the vacuum solenoid has enough resistance built into it to keep the current at a safe level for the Harlan. If you tried to power something like a high wattage light bulb (for instance) directly from the Harlan, you'd fry it.
Old Aug 6, 2003 | 07:11 AM
Sprint's Avatar
well i got a NOS switch
Old Aug 6, 2003 | 10:29 AM
AllGo's Avatar
no relay here for over 6 months and my harlan/mevi works great. the harlan can handle the very small amount of ground needed for the map switch to work. it is not that fragile, sprint uses it for a nitrous solenoid and that is sure to put more current strain than a tiny map switch, just don't let it get wet.
Old Aug 6, 2003 | 10:38 AM
Sprint's Avatar
i didn't say nitrous soleniod.. i said Nitrous RPM Switch
AaronL
Nov 15, 2020 11:52 AM
zmcneely13
Sep 26, 2015 02:26 PM
Bluenissan
Sep 20, 2015 08:54 PM
BrandonCause
Sep 14, 2015 10:41 PM
