Knock Sensor 97 Maxima
Old Aug 5, 2003 | 02:26 PM
akbarrasheed's Avatar
Hey what's up you all,
I'm trying to figure out how many knock sensors does my Maxima have? The check engine light came on and I pulled the code 0304 which says I need to replace my knock sensor. I called a local auto store and they said my Maxima has more then one knock sensor is that true?? If it is how do I figure out which ones I need?? Please help!! Thanks in advance
PEACE
Ak
Old Aug 5, 2003 | 02:34 PM
mb1's Avatar
mb1
Re: Knock Sensor 97 Maxima
PEACE
Ak
no, there's one under the intake manifold. email MsMpm2000@aol.com for a cheap used knock sensor.
Old Aug 5, 2003 | 02:42 PM
Thanks man but how do I figure out which knock sensor to replace?? code is 0304?
Old Aug 5, 2003 | 02:47 PM
mr2good's Avatar
PEACE
Ak
To my limited knowledge, getting that code (which I currently am getting) means that your knock sensor is detecting a knock. I believe mine is going off because their is a rattle in my timing chain area.
I don't think it means that your knock sensor is bad, but that it is detecting a knock. Maybe it means both?
Old Aug 5, 2003 | 04:40 PM
WhiteMax96's Avatar
You only have 1 knock sensor on your Maxima and you can be sure of that.
I had the 0304 code last week and change mine. No more code and the max is pulling strong again.
Old Aug 6, 2003 | 04:49 AM
kenju4u's Avatar
Knock sensor code on the ECU means there is a malfunction in the knock sensor circuit. Usally means knock sensor has gone bad. You need to replace it. here is how to replace it:
http://www.motorvate.ca/mvp.php/507
Old Aug 8, 2003 | 09:27 PM
Newyorkgee's Avatar
Got the 3,4 .....changed the KS, Got back power and when I ran the ecu got the all clear 5,5 total cost $168 did the swap myself. Got the KS from the mafia I mean dealer for $168 if I had known better I would have gotten it on line, If you choose to change your Ks check the fourm some of the other family members have good sites with great deals...Hope this helps and good luck
Old Aug 9, 2003 | 08:36 AM
vol245's Avatar
Bummer. I got my knock sensor on ebay for $80. I just finished the job, which was a piece of cake with the right tools
Old Aug 9, 2003 | 09:32 AM
nismology's Avatar
Just because you are getting the knock sensor code doesn't necessarily mean the KS is bad. It might just be doing it's job by detecting knock. Clear the codes per the directions in the stickie and see if it comes back.
Old Aug 9, 2003 | 09:35 AM
Kevlo911's Avatar
Kevlo for President
correct me if i am wrong, hte KS is bad only if u get the Ghost Code
or u can test the ohms on it
Old Aug 9, 2003 | 02:05 PM
vol245's Avatar
I was getting the 3-4 code along with a 5-3 which is the front right oxygen sensor. I replaced the O2 sensor and reset the codes. After driving it for a few miles I checked and had a 3-4 code. I just replaced teh knock sensor, reset the codes and drove it about 20 miles. I checked the codes when I got home and had the 5-5, so I guess it worked. The car is a '96 Inifinti I30 with 155K miles on it.
Old Aug 9, 2003 | 03:05 PM
UncleMax98's Avatar
Took me three hours (and many trips to Sears to purchase tools) to replace mine. I am kind of slow and the lack of tools does not help. I got the knock sensor (Bosch) from thepartsbin.com, $115 delivered. Much cheaper than at Nissan dealer. The Bosch sensor is indentical to the Nissan one, down to to marking on the sensor itself.
Old Aug 9, 2003 | 03:57 PM
vol245's Avatar
I was going to buy the Bosch sensor from one of those places that sells them for $115, but someone told me that one was for sale on ebay.
I was also given this link http://www.skippynet.com/maxima/knocksensor.htm
which gives great instructions and says what tools to use. I ordered them from craftsman.com. I didn't like the quarter inch drive extension though. If felt like it was going to snap. I used a 10 inch and a 6 inch 3/8 drive and a 3/8 to 1/4 adaptor. I was done in about half an hour.
Old Aug 9, 2003 | 04:55 PM
nismology's Avatar
To the original poster once again, clear the CEL and see if it comes back before going out and buying a new one. If it doesn't come back, your KS was just doing it's job. And even if it does come back, it might be your engine knocking and something bigger might need to be fixed. You might wanna check the resistance that the sensor has. Do you feel like the power is being drastically diminished??
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
follyburr
Aug 7, 2015 09:50 PM
yat70458
Aug 3, 2015 01:16 PM
