having lots of hesitation
Old Aug 6, 2003 | 03:28 AM
twizztedangel's Avatar
i have been having a lot of hesitation around 40mph on the freeway, and my car has also been cutting out at ldle and when i slow down for a light, and hesitation when i take off from a light. pls help
Old Aug 6, 2003 | 04:46 AM
kenju4u's Avatar
tuneup? TB cleaning? fuel filter? air filter? reset ECU...
Old Aug 7, 2003 | 08:56 AM
95Max's Avatar
Your MAF could be going. Bad TPS.
Any codes?
Old Aug 7, 2003 | 11:42 AM
2naboy's Avatar
Any codes?
Thats right your mass air flow sensor is probably gone bad. They are meant to last a long time but this is not always true. Best idea is to run codes, and if nothing shows then you may have to go to the dealership. Before you do that, see if you can find someone with a maxima and switch the maf with him and see if there is any difference. If problem persist try other sensors, trottle positioning sensor, etc. If any of that dont work then dealership it is.
Old Aug 7, 2003 | 01:51 PM
ManualMaxima's Avatar
5th Gen till she dies!
how do you check codes. Do you have to have one of those little things?
Old Aug 7, 2003 | 02:53 PM
2naboy's Avatar
Go here
http://forums.maxima.org/showthread.php?threadid=104931
Old Aug 7, 2003 | 02:58 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
And Spark Plugs, Or coil packs....
Old Aug 7, 2003 | 09:12 PM
thanks man, did not know where that was posted. I am afrid to check incase anything is messed up, cause with my luck it will like blow up or some ****.
Old Aug 8, 2003 | 02:17 PM
thanksguys for the help i will try and check those things. i have not been getting a check engine light and i just replaced the spark plugs with new ngk's.
mclasser
22
Nov 12, 2020 01:58 PM
BobTX10
Oct 7, 2015 08:43 AM
bernyp
Oct 2, 2015 10:10 AM
