Help with indiglo gauges!! Im screwed??
Old Aug 6, 2003 | 11:05 PM
FazliS85's Avatar
I installed those reverse indiglow gauges in my 97 max and everything works except the fuel gauge. I made sure to see what it was on and made a mark. I just put the new gauges over the existing ones and tapped into the blue dimmer wire. The needle isnt stuck cause i took it apart to check. What should I do?? Stealership is gonna screw me over!! Im in the ny huntington area...any suggestions?
Old Aug 6, 2003 | 11:22 PM
Nismo3112's Avatar
Custom User Title
Did u make sure u plugged all of the connectors back in when u took the guage out?
Old Aug 6, 2003 | 11:24 PM
FazliS85's Avatar
Yea all the plugs are in...i dont know whats wrong!! The gauge needle seemed motorized unlike the rest of them which felt loose.
Old Aug 6, 2003 | 11:25 PM
95emeraldgxe's Avatar
take the guage off, and then turn on the car to see if the needle registers, if it does, then that means the needle is sticking and to solve that problem you just need some hot glue or some double sided tape
Old Aug 6, 2003 | 11:29 PM
FazliS85's Avatar
ok...ill try taking it off first thing in the morning...i used hot glue for all of them and made sure they were flush. I put a little dab in the corners. thanks 95emeraldgxe
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
