jus got a 95max
Old Aug 8, 2003 | 10:33 AM
bgtcket21's Avatar
jus got a 95max
im new to all this jus picked up my 95max gle last week love everythin except the lights i ordered some tailights and sum diamond cut bumper lights but im lookin for the corner lights and headlights? can i just buy 99max headlights and corners or are there any clear corners out there(i found corners for a 94max?)? also i ran an ecu check and found out i got a bad knock sensor and engine coolant sensor...how important/easy are these to get fixed?
Old Aug 8, 2003 | 10:49 AM
Jatan's Avatar
http://forums.maxima.org/showthread....hreadid=239330
Old Aug 8, 2003 | 11:03 AM
bgtcket21's Avatar
thanks for the link...i really was wonderin how important it would be to change those now though
Old Aug 8, 2003 | 11:24 AM
Jatan's Avatar
Replace the coolant sensor (maybe get a used one from a junk yard or from someone on this forum) and clear the ECU. If a knock sensor code comes back then it's bad (you have to check it after a few days, it's a ghost code so it won't turn the CEL on). If you are running 91+ octane gas, then you can bypass the KS as a temporary solution.
Old Aug 8, 2003 | 11:27 AM
bgtcket21's Avatar
ok...thanks...anyone know about the headlights/corner lights?
Old Aug 8, 2003 | 11:36 AM
JamesAvery's Avatar
custommaxima.com has a variety of lights. although I had a bad experience with them, they may have gotten better since then. If you just want less "yellow" headlights, check out phillips blue-vision. THey are not blue, but whiter and pretty damn cheap
MaxRPM6
Sep 11, 2015 06:56 PM
MaximaPower
Mar 20, 2002 07:46 PM
areX
Jan 9, 2002 07:09 AM
MaxedOut2g
Nov 10, 2001 11:50 AM
areX
Oct 23, 2001 02:39 PM
