Unusual Knock Sensor Question...
I'm about to swap in a new knock sensor. I was looking at it and wondering if I could make it easier to do...
What is stopping me from bolting the new knock sensor to a different part of the engine block? It would still work, no? It would still sense detonation (given the extraordinary accoustic conductivity of metal)
The knock sensor of my truck's V8 is bolted right at the bellhousing a full 12" from cylinders 1 and 5. That's factory and it works fine.
This is a great idea. Please let us know how it goes. The entire Maxima community will be in your debt. I just changed mine so I am good for another few years, but I dread the prospect of another KS change in the future.
Re: Unusual Knock Sensor Question...
Why do you want to bolt it to another place on the block?
It was designed to work between the heads.
If you want to keep it hooked up but keep it from retarding your timing you can mount it on the firewall.
There are a few racing teams that do this successfully.
It seems the ringing in a performance Y-pipe can cause phantom pre-ignition conditions which set off the KS. To eliminate this they mount the KS on the firewall.
IMPORTANT POINT: They also ALWAYS run high octane fuel and have everything else in their engines perfectly tuned first.
Beware that removing your KS from the engine or eliminating it with a resistor will allow your engine to run maximum spark advance whenever it wants.
At minimum you could easily burn up your valves if the rest of your engine isn't tuned perfectly.
I've done it. It works.
I didn't see any difference.... but my car has EVERYTHING tuned properly. I put it back on the block so I don't have to wonder if I'm killing my Max.
my 2 cents.....
my 2 cents.....
It should be able to bolt anywhere on the block and still be effective. It's picking up spark knock as vibrations using a piezo element.
I guess the problem with mounting it elsewhere is you may pick up phantom vibrations from the injectors, etc.
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
