Is your Max reliable?
My Max has 210,000 miles on it. I usually change my oil every 5-7,000
. Tranny fluid every 30,000 miles. I drive it into the ground everyday. I bought it when it had 23,000 miles on it. So far this is what I've had to fix.
82,000- Starter $50 DIY
103,000- Starter $50 DIY
134,000- Starter $50 DIY
166,000- Knock Sensor $105 DIY
176,000- Belts, R drive axle boot busted $180 replaced axle
186,000- L drive axle boot busted $110 replaced axle
187,000- Blown struts and shocks ( found out after bending 2 sets of
19" rims) $360 installed GR2's
189,000- Leak in tranny gasket $40
202,000- EVAP Solenoid $2 w/ WD40
205,000- Changed both control arms (bad bushings) $260 installed, FR O2 sensor FREE installed from junked car
206,000- R drive axle boot $90 replaced
I think I've been pretty lucky. What do you think?
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
My max is very reliable.
48,000 Tune-up DIY
49,000 Brakes DIY
54,108 All Fluids flushed (brake, steering, coolant, tranny, oil, injectors cleaned)
74,416 Evap purge flow monitor (hose was broken from FSTB) DIY
80,286 Tranny Died
81,099 Brakes DIY
Fluids will be done really soon. No problems yet.
48,000 Tune-up DIY
49,000 Brakes DIY
80,286 Tranny Died
81,099 Brakes DIY
50k - Alternator
65k - Both front Axles
Now (79k) - Rear O2 Sensor needs to be replaced.
THat's it as far as actual factory parts going bad.
All the other things I've replaced have been mods/upgrades
approx. estimates on my bro's car when he had it-
somewhere in the mid-upper 40K - front brake pads replaced
somewhere in the 60K - vent control valve replaced
when I had it last spring-summer -
74K - engine flush by dealer
81K - alternator replaced by recall
82K - rear brake pads replaced
when its mine once again
>100K - 60/90K service, brakes, tires (one step at a time of course)
I would say despite my brother having 2 accidents w/ it in '00 (driver door, front end), his max has stood the test of time
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
mkaresh
03-12-2018 06:48 PM
magiconthetire
10-26-2015 09:03 PM
