I just found out my rear caliper have been DEAD for at least 3 months...
I got my brakes and everything so i decide to put them on. Well after taking out the rear caliper and pads I try to put on the new ones. They are 2x thicker and the new rotor is almost 2x thicker. With the pads in the caliper there is Absolutely NO room for the caliper. We tried to let out the air but the piston thingy is shot. Fun stuff...
Originally posted by ivelweyz
What tool is that???
You need to turn the piston clockwise to get it back in. There is a special tool the will grab the nubs on the piston so you can turn it. You can also use a pair of needle nose pliers to grab the nubs and turn the piston clockwise to move it back into the caliper.
Your new brake pads should fit nicely once you've done that.
Also is it normal for the rear dust boots on my shocks to be torn into single rings and then sucked inside the shock???
Originally posted by njmaxseltd
I had a feeling that was going to be the response.
i just fixed my caliper today when the shops said i need a new one. take everything off like your doing a regular brake change. if the piston is stuck like mine was. pump your brakes and e-brake it should pop out easy. after just scrub the piston down on the sides so it's smooth. slide it back in and c-clamp it. should push down with no problem. if it does just take a little razor blade and saw off some corrosions little by little. that's what mea and my handy smart friend did. works all good now. saved money on buying a new caliper.
Believe me buddy I tried ant both of the rear pistons are shot. My entire rear rotors are rusted, no signs of brake use in a long time. To add to the mess all 8 bolts on the right side of the car broke in half. Worst part is that the pins that hold the 14mm bolts need to be replace cause they have the ends of the bolts in them. Where can I get the bolts and the pins? I tried dealerships but they keep sending me to other dealerships and none of them have any in stock. Worst part is that I haven't driven my car since Friday...
hey just trying to help you out. the brake shops said mine where shot. but voila my boy got that piston out and back in and working when 2 shops said i need new calipers and 2 other friends said dont even try it. as for bolts and pins go to advanceautoparts.com
Originally posted by mr. bunna
doesn't hurt to try. but hey good luck with your brakes hope you dont have to spend too much money on it.
A link of the pin
http://www.partsamerica.com/PartDeta...pe=351&PTSet=A
Re: I just found out my rear caliper have been DEAD for at least 3 months...
Slamrod
Apr 10, 2016 05:24 PM
Huttig2009
Sep 25, 2015 03:31 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
