Electrical Problem With Tails!!
Old Aug 11, 2003 | 01:17 AM
zemp68's Avatar
Ok, I installed new tail lights for the max, and put in a nice little multi-led red bulb for the blinker, and totally lost my hazard blink, plus quickened my blinker frequency. I tried to change back to the original white bulb, but it didn't work. Any suggestions?
Old Aug 11, 2003 | 06:16 AM
njmaxseltd's Avatar
You have the wrong bulb in a socket someplace.
1156 where an 1157 should be or vis-vers
Old Aug 11, 2003 | 07:42 AM
zemp68's Avatar
ok, thanks, let me check it out...
Old Aug 11, 2003 | 11:33 AM
mclarke's Avatar
you also need to be carefull with those LED bulbs, they have a higher resistance then regular bulbs and can cause a lot of problems, I used to see it on my accord when i had the clear taillights in.
Old Aug 11, 2003 | 01:21 PM
RAZER's Avatar
My blinkers go fast and blow the fuse about every week, what can i do?
Old Aug 11, 2003 | 01:23 PM
zemp68's Avatar
OK
oK, i JUST FIGURED IT OUT...THOSE LED BULBS RUN TOO MANY WATTS AND BURNED OUT MY FUSES AND HARNESS FOR THE LEFT BULB. I REPLACED THE FUSE AND I'M GETTING A NEW HARNESS FROM THE DEALER TOMORROW. i WILL NOW STICK WITH THE REGULAR RED STOCK BLINKER BULBS.
knight_yyz
Nov 6, 2015 02:34 PM
