Should I spend $60 on the KYB bumpstops???
Old Aug 11, 2003 | 01:03 PM
blk97se's Avatar
I'm about to order Progress springs and AGX's, should I go ahead and get the KYB bumpstop/strutboots? Do AGX's come with any bumpstops?
Old Aug 11, 2003 | 01:08 PM
endus's Avatar
An atavistic endeavor...
They don't come with them. You can cut your stock ones, or order the KYB ones. I ordered the KYB's.
Old Aug 11, 2003 | 03:31 PM
ny96max's Avatar
Re: Should I spend $60 on the KYB bumpstops???
hell yes!!
KYB are made from ureathane vs. rubber like the OEM and will last you twice as long. Not to mention the precut bumpstops to make your ride a lil smoother.
Ant
Old Aug 11, 2003 | 03:33 PM
zeff789's Avatar
Where do you guys buy your KYB bumpstops and dust boots, etc?
Old Aug 11, 2003 | 04:26 PM
RobUsaf81's Avatar
if you got an SE i think you can use the ones you have and just cut them im assuming. Since the SE has the polyurethane mounts.
Am i correct?.. cause Ive wondering about that too.
Old Aug 11, 2003 | 05:56 PM
ny96max's Avatar
i got mine from www.Tirerack.com for $55 shipped!
Ant
Old Aug 11, 2003 | 06:16 PM
pezking4's Avatar
Also, check Taylor Automotive for KYB products.
Old Aug 11, 2003 | 06:33 PM
zealotnyc's Avatar
If I get new shocks and struts, but not springs, I need Dust boots but do I also need Bump Stops?
Old Aug 11, 2003 | 07:18 PM
pMB's Avatar
pMB
go to Pepboys and pick up their $5 "Silver E" universal dust boots.
then use your stock bump stops (no cutting). this way, you'll save $$.
Old Aug 11, 2003 | 08:15 PM
philpoe's Avatar
4 Maximas and counting
Maxima boots or others?
Are we supposed to order stock boots for a Maxima?
I thought I recalled that we order fronts/rears from different cars to turn out the best for us. I believe one set was from a Mustang.
Any info here? I need to order a set
thanks
Ant
Old Aug 12, 2003 | 05:38 AM
Jatan's Avatar
KYB Dustboots: SB103 and SB108
Old Aug 12, 2003 | 08:10 AM
ny96max's Avatar
Ant
Old Aug 12, 2003 | 08:38 AM
philpoe's Avatar
Front vs Rear?
This may be painfully obvious, but which are for the front, and which are for the rear?
Or is it that they can't be mixed up?
Old Aug 12, 2003 | 09:01 AM
ny96max's Avatar
Re: Front vs Rear?
they cannot be mixed up!
Ant
Old Aug 12, 2003 | 09:23 AM
skeetsmax's Avatar
ORDER THE ONES FOR A MAXIMA>>> whoever said something about trw products being repackaged in kyb boxes was flat out wrong... someone said get trw part number 14103 and 14108...ie the mustand and miata...so i do that and the bumpstop is totally different than my stock bumpstop and dustboot.... so i had to cut the new ones and "make them fit" therefore I was strongly advise you ordering the kyb parts from tire rack...assuming they will match the stock boots...or just getting new ones from courtesy nissan or something...........
Old Aug 12, 2003 | 10:24 AM
Jatan's Avatar
I think that (not 100% sure) 103 is for front and 108 is for back. Just take off your old ones and see which ones look alike or something One of them comes with a ring or gasket or something like that, just throw that out. I'm getting mine installed tomorrow or Thursday so I don't know.
Old Aug 12, 2003 | 10:37 AM
NYCe MaXiMa's Avatar
I had to do the same with Max4u when we were installing my strut boots/bump stops.. When you search the Maxima has no bump stops / dust boots sold at tirerack.com but they sell them as a package with something else for a lot more $...
i got the mustang and miata ones and the rears had to be cut quite a bit because they wouldn't fit under the top shock mount..
Old Aug 12, 2003 | 04:06 PM
maximaah's Avatar
Called TireRack.com and they do not show KYB dust boots that fit 4th gen max. SB103 fits 3rd gen and SB108 not for Max at all. Just want to check that these are really meant for front/rear on 4th gen max (GXE) with KYB GR2's.
Otherwise I'm going to have to go OEM...
Old Aug 12, 2003 | 09:07 PM
philpoe's Avatar
Hmmm.. Strange
If I go to tirerack.com and search for a 96 Maxima SE, I get front KYB boots for $41 each and rears for $5 each.
Old Aug 12, 2003 | 09:24 PM
Jatan's Avatar
Re: Hmmm.. Strange
I already have mine with me and going to get them installed soon (as soon as the other parts arrive) so I'll know then. There have been tons of posts on this. Try searching on the test site or look back on the old pages.
Those are strut mounts not boots. They don't make boots for ours cars, we use them from other cars.
Old Aug 12, 2003 | 10:04 PM
SpeedCrazie's Avatar
Does it matter if you have Ground Controls instead of springs? Is it still a "should have" ?
JP
Old Aug 12, 2003 | 10:06 PM
I H8 COPS
ok
Old Aug 12, 2003 | 11:20 PM
maximaah's Avatar
Re: Re: Hmmm.. Strange
I already have mine with me and going to get them installed soon (as soon as the other parts arrive) so I'll know then. There have been tons of posts on this. Try searching on the test site or look back on the old pages.Those are strut mounts not boots. They don't make boots for ours cars, we use them from other cars.
Cool. I wish I'd ordered them with my GR2's from tirerack, but oh well, I'll go back and order them anyway. Looks like another week before I get my GR2/Progress stuff installed <sigh>.
Old Aug 13, 2003 | 01:39 AM
Gates's Avatar
My order total was $29.82 . Good Price!
Old Aug 16, 2003 | 09:44 PM
philpoe's Avatar
So KYB SB103 and SB108 are OK?
So, do the KYB Dustboots SB103 and SB108 fit the Maxima, and the TRW models do not?
Or do the KYB dustboot SB103 and SB108 boots lead to trouble?
thanks
ORDER THE ONES FOR A MAXIMA&gt;&gt;&gt; whoever said something about trw products being repackaged in kyb boxes was flat out wrong... someone said get trw part number 14103 and 14108...ie the mustand and miata...so i do that and the bumpstop is totally different than my stock bumpstop and dustboot.... so i had to cut the new ones and &quot;make them fit&quot; therefore I was strongly advise you ordering the kyb parts from tire rack...assuming they will match the stock boots...or just getting new ones from courtesy nissan or something...........
Old Aug 17, 2003 | 05:48 AM
Jatan's Avatar
Got my suspension installed and car aligned yesterday. The mechanic was impressed by the smaller springs and nice struts/shocks. I was helping him do it so it would be done faster. Mostly all of my stuff was rusted
The rear dustboots fit perfectly BUT they're hard as hell to make them go down (you have to push down real hard so it goes on the bottom of the little circle thing). The front bumpstops are a little smaller in size, but it works fine. Haven't had any trouble with them.
I'm glad I changed my springs b/c the old ones were rubbing and rusted These new ones are great. The front looks nice and low. Just waiting for the back to settle down. I don't have a cam to take a pic, but the rear is like a before shot and the front is like a after shot It rides great. You feel the bumps more, but the handling is excellent. Now I just need a FSTB
Old Oct 8, 2003 | 02:32 PM
chris j vurnis's Avatar
I just took a look under my front wheel well.
Seems like my stock bumpstop is about 2 inches long.
How long is the bump stop for a KYB?
Actually, the bump stop I have on there came from an old Tokiko "Blues" model shock which I suppose is close to OEM spec.
If any of you can confirm that the KYB bump stop from TireRack is significantly shorter than the 2" OEM version, then I'll have the confidence to buy it.
I couldn't really see the bumpstop on the rear with the tire installed. Is it worth it to get new rear bump stops from KYB?
Old Oct 8, 2003 | 02:58 PM
tynant's Avatar
Im about to purchase a set of used agx shocks/struts with H&R springs and a rsb...should I go ahead and get the bump stops before having this stuff installed? What exactly do they do? Do they improve the handling of the car? I have a totally stock suspension right now, so Im am sure it will be like night and day when I have everything installed at once!
Old Oct 8, 2003 | 06:01 PM
maximaah's Avatar
Yes, you will need the bumpstops. They are actually a combination of bumpstops and dustboots. They keep the strut/shock from compressing fully to the end of the shaft on a hard bump.
Old Oct 8, 2003 | 06:42 PM
eskim_77's Avatar
Just received AGX/Eibach... My question is, do I have to order Eibach Alignment kit?
Is Dustboot/Bumpstop samething? I saw many people ordered from Tirerack which I will do tomorrow.
What is installation cost of these shocks/spring? This mechanic I used to go said, he would charge me 180/each(720 for labor) which I think crazy? Any good mechanic in NJ area?
Old Oct 8, 2003 | 07:05 PM
Jatan's Avatar
$720 is crazy. Go ask Tom http://forums.maxima.org/showpost.ph...00&postcount=9
More info on dustboots http://www.tirerack.com/suspension/s...del=Strut+Boot
Old Oct 8, 2003 | 07:37 PM
Lo-Tse's Avatar
The bump stop will protect your shock /struts from bottoming out when you hit a really big hole. The piston rods in the shocks /struts could hit the bottom of the body if you let it bottom out. Get it!!
Lo-Tse
Old Oct 9, 2003 | 02:37 PM
tynant's Avatar
Lo-Tse
so can we get these boots from tirerack.com or not? I read through the posts and I am still confused! JaTaN says they do not fit but then he says he has them? Which is it!? If not from tirerack.com where? I tried that other place but couldnt find them listed...
Old Oct 9, 2003 | 02:39 PM
zeff789's Avatar
www.cattman.com has them...
Old Oct 9, 2003 | 06:41 PM
Lo-Tse's Avatar
I also bought mine from Cattman. Call them up.
Lo-Tse
Old Oct 9, 2003 | 09:06 PM
Jatan's Avatar
I never said "they do not fit" all I said was it was hard to get it down the piston tab thing and they don't make the boots for our cars. We can use it from other cars (we get one from a Mustang and one from a Miata). Get SB103 for the front and SB108 for the rear. You'll need 2 of each.
Old Oct 13, 2003 | 11:56 AM
2k2MerlotSE's Avatar
JUVIN's ride
Lo-Tse
They say it is for the AGX's. Are those the ones? $60
Would anyone have a pic of it on the strut?
Old Oct 16, 2003 | 05:58 PM
Lo-Tse's Avatar
As far as I know, Cattman only carry boots for the AGX's. I bought the shock-Struts-springs-boots as a package.
Lo-Tse
Old Nov 7, 2003 | 02:13 AM
PeTeRtheEaTeR's Avatar
is it necessary to order all 3 sets of bumpstops, dustboots and shock mounts if I have 150k miles on them? do u think they're worn out? where's a good place that has all 3?
Old Nov 7, 2003 | 03:51 AM
Jatan's Avatar
If you get KYB dustboots, they come with the bumpstops (SB103 and SB108).
I did buy new strut mounts for the front, but that was a waste of money for me since my old ones were fine. You'll have to see if they're bad or not.
You won't need rear mounts since they don't go bad because they are metal or something (Dave B. told me that ). So buy only the front ones if you need them (stay away from KYB strut mounts, get OEM)
